Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 10-11-2018, 11:55 AM   #1
thuss
City & State: london
My Country: uk
I'm a: Knowledge Seeker
Default Hitachi lcd tv L42VK04U not staying on
Hi
I am trying to repair this tv for my neighbour .
The red standby light is on.
I switch the tv on and the standby light flashes blue and backlights flash for a couple of seconds and then turn off.
Then the standby light justs cycles between red and blue.
The power supply is a vestel 17PW26-5 v.3.
The main board is a 17MB65-2.
I have replaced the inveter board and it does the same. Ive disconnected the inverter board but still the same.
On the power supply the white connecter top right hand corner I get the following voltages
Starting at the top with column on the left hand side
readings are
standby voltages /on voltages
0 / 0
7.86 / 8.97
2.57 /0
0.36
0 /3.57
11.86
5.03
3.39
0 /3.39
0 /3.39
0 /3.39
0
0.23
0.23
Power supply top right column nearest to main board
standyby voltage / on voltage
0
0
0
0
0.11
11.85
3.39
0 /5.15
0.24
0.24
0.1
0.28
0 /3.15
I have checked some of the caps on a meter and they are fine theres no leaks
Any pointers would be really appreciated -
thuss is offline   Reply With Quote
Old 10-11-2018, 01:00 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Hitachi lcd tv L42VK04U not staying on
check the connector that goes to the inverter. looks like you don't have any 24V for the inverter on the PSU. First check the voltage on the main filter capacitor, in order to see if the PFC is running or not. If the PFC is running, check the rectifying diodes on the output section of the 24V rail.
CapLeaker is offline   Reply With Quote
Old 10-11-2018, 05:32 PM   #3
thuss
My Country: uk
Thanks- forgot to mention I am getting 24v from the top left connector block on the psu- on the inverter board fuse there is 24v. Ive checked the diodes they seem fine.
I will check the main filter cap
Old 10-11-2018, 07:10 PM   #4
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Do the backlights come on at all?
Old 10-11-2018, 08:10 PM   #5
thuss
My Country: uk
Hi yes the back lights do come on for about 2 seconds.
Ive checked the fan chip seems fine high ohms,the smd caps surrounding the fan chip seem fine no shorts.
Old 10-12-2018, 01:38 PM   #6
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
compare the secondary windings on each HV transformer for the backlights. They have to be in line withing 3% of each other.
Old 10-12-2018, 02:01 PM   #7
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Can we see the pcitures of the Inverter board without the metal shield?
What Voltages do you get on the connector of Inverter board that goes to the power supply board? Pin names for those pins?
__________________
budm is offline   Reply With Quote
Old 10-13-2018, 09:28 AM   #8
thuss
My Country: uk
As req With ref to the new attached photo of the connection wires that go from the psu to the inverter board.
Ive started with the green wire as number 1. (standby/ on voltage)
1 green wire on psu (standby /on voltages)- 0.6v/0
2 Pink wire 0/3.38
5 Brown wire 0/0
6 Brown wire 0/0
7 Brown wire 0/0
9 white wire 0.2/24
10 white wire 0.2/24
11 white wire 0.2/24
12 white wire 0.2/24
Ive have tried two inverter boards- still the same results
Old 10-13-2018, 10:37 AM   #9
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Try disconnecting one of the lamps from the inverter and see if the backlight still comes on for 2 sec. Then reconnect that lamp and disconnect the other lamp and try again. There may be a faulty ccfl
R_J is offline   Reply With Quote
Old 10-13-2018, 10:58 AM   #10
thuss
My Country: uk
before I remove the lcd screen to get at the tubes- shouldn't the PSu have a constant 24v on the connector block from the main board.
Old 10-13-2018, 12:54 PM   #11
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
check these transformers first, before you take stuff apart.
Old 10-13-2018, 02:10 PM   #12
budm
budm's Avatar
My Country: USA
#1 green wire on psu (standby /on voltages)- 0.6v/0
#2 Pink wire 0/3.38
One of those two wire should be for BL-ON, another one will be for Dim control.'
The Voltage on #1 looks to be too low, you should keep the meter on that pin ten turn the TV on to see if it jumps up over 0.6V and then drops own to 0V or not, then try disconnecting just that wire #1 from the inverter board and see what Voltage you will get on that pin of the inverter board when you turn on the TV.
Old 10-14-2018, 12:11 PM   #13
thuss
My Country: uk
2 Pink wire 0/3.38
5 Brown wire 0/0
6 Brown wire 0/0
7 Brown wire 0/0
9 white wire 0.2/24
My mistake the green wire has on standby 0.6v but today switched the TV on backlights came on for two seconds and the voltage went to 3.36v and then dropped
Cut the green wire same result as above just no backlights flash forgot to mention transformers seem fine
Old 10-14-2018, 04:10 PM   #14
thuss
My Country: uk
It's definitely the psu I repaired a 17pw26-5 (one main white plug)out of a toshiba that was lying about and the tv fires up fine- but not with the 17pw26-5(black and white plug)
Old 10-14-2018, 04:20 PM   #15
budm
budm's Avatar
My Country: USA
The control signals for the inverter are generated by the main board, they are just routed through the power supply board for neat wiring.
Old Today, 08:44 AM   #16
thuss
My Country: uk
Just sourced another psu worked straight - couldn't work out what was wrong with original psu
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
