optical convex lens?
    HI have a question, what those TV backlight LED lens (optical convex lens? ) are called. If they fall, how can we glue it back? Hot glue gun or super glue?
    Re: optical convex lens?
    not hot glue or superglue - the leds get hot.
    maybe clear silicone. (neutral cure type)
    search on ebay for a chinese product called 705 "705 silicone"
    https://www.ebay.co.uk/itm/302814126123
      Will silicone glues take too long to harden?
        how long is too long?
        that stuff is reasonably fast.
          It has to be flexible (silicone rubber) because of the temperature swings. Hard epoxy just cracks.
          24hr cure for a big blob or thick run, and 1hr for thin films. It's the thickness that mainly affects cure time. Humidity and airflow, temperature also play a part.
          I leave the stuff overnight, or several hours upright at least if the lens is heavy.
            Can I use 10 seconds UV glue for promptness?
              you can try.
              but first, harden some on a bit of tape or card, then bend it
              if it cracks it wont work, if it bends then it might.
              it also has to be heat-proof.
                Shopjimmy used super glue!
                How to Replace Single LEDs for an LED TV - ShopJimmy LED Strip Rework Station Tutorial
                https://www.youtube.com/watch?v=EZVQKEp6jxk
                this guy used UV glue
                LG Led TV 32LN5700 No picture :backlight Repair,change Smd Led without hot air! easy way !!
                https://www.youtube.com/watch?v=YrZ4bAFiUg8
                Top 5 High Temperature Resistant Adhesives - Master Bond
                https://www.masterbond.com/enews/top...adhesives.html
                  shopjimmy are fucking assholes!
                  the heat from the led will cause the cyanocrylate to soften and evaporate - then the vapor will form a stinky foggy powdery coating on everything!!!
                    454,990 viewers from shopjimmy might be fix led lens using superglue which vapors are very irritating. UV glue or UV silicone glue would be a better way.
                      A....three crops of UV glue.
                      B....UV light for 10 seconds.
                      C....it is ready.
