Hi guys,
We got another donor tv to work on here. The tv's model number on the back of the case is a Dynex dx-42e250a12. When we originally got the tv it would not power on at all and the power supply board showed no signs of power. We were unable to locate the source of the problem and decided to save time by ordering a used replacement power supply board. The power supply board is marked as a Hisense RSAG7.820.4543/R0H.
After receiving the new board, we now have a repeating single red blink on the front control panel. I was unable to located anything that referenced blinking error code for the light. There is a faint ticking noise coming from what sounds like the left side of the board. The voltages measured on the XP901 connector appear to rise at the "tick" and then fall back to near 0 as if its trying to start and something is failing.
The listed voltages for connector XP901 are:
GND
STBY
5V_S
12V
12V
GND
GND
PWM
SW
GND
GND
18V
18V
Actual measured voltages with all boards connected:
.5-1V
.5-2V
1-3.5V
1-5.5V
0V
0.5V
3.9-14V
2.9-15V
The LED connector has only a couple of volts on it.
With all boards disconnected the standby voltage stays steady at 5V.
There is no change with the LEDs or the TCON disconnected.
I was not sure if this power supply could be jumped to allow it to power up without the mainboard so not much testing was done with everything disconnected.
Checked for leaky or bulged caps and found none. Fuse also tested good.
Does this seem like we got another bad power supply board or is it possible that something on the mainboard is causing problems?
GND
STBY
5V_S
12V
12V
GND
GND
PWM
SW
GND
GND
18V
18V
.5-1V
.5-2V
1-3.5V
1-5.5V
0V
0.5V
3.9-14V
2.9-15V
