Perhaps the low 3.5V is causing problems with the rest of the logic.
What does the manual say about the ACDETECT? I.E., does it say that when AC is detected, the ACDETECT pin is high? low? what about if there is a power failure (AC power drops out, due to power outage, or being unplugged)?
AC Detect is generated on the SMPS, by rectifying a small sample of the
A/C Line at D102 and associated circuitry and routed to the Controller (IC701) where it outputs at pin 15 and sent to P813
pin 18 to the Main Board where it is sensed and monitored by the Main Microprocessor (IC1). The AC Detin this set works differently than most. If AC Det is missing the Microprocessor will turn off the television in about 10 seconds after turn on.
This will happen each time turn on is attempted.
That would mean that when there is AC, the ACDETECT would be high, as it is when the mainboard is connected in your case.
I don't know why it would be low with no mainboard, but I think some of the filter caps next to the small heatsink on the bottom right could be dried up inside.
ok the 3 capasitors? I will remove and test tomorrow. It looks like there is another rectifier, an IC and another thing with 3 legs fitted to the heat sink.
So it this like another 5v supply circuit and those capasitors are filtering out noise?
Reason: grammer
AC Voltage is supplied to the SMPS Board at Connector SC101 from the AC Input assembly. Standby 5V is developed from
160V source supply (which during run measures 380V measured fromthe primary fuse F302).
This supply is also used to generate all other voltages on the SMPS.
The STBY5V (standby) is B+ for the Controller (IC701) on the SMPS and output at P813 pins 11 and 23 then sent to the
Main board for Microprocessor (IC1) operation.
If possible. I suspect the 5V MAIN is derived off here...
If the 12V is also low by about the same amount (30%), then the suspect would be the primary side, controller IC, or TL431.
I say TL431 because I now recall budm had a Samsung monitor with low rails, and it turned out to be the TL431 (voltage reference IC; for the feedback loop.)
