TV wouldn't power on. Power LED would go from red to blue but no video/sound. Info. found in this forum pointed to a defective Main Board T.RSC8 12305.
Original board with LTA400HM24 firmware chip on it couldn't be found. Purchased a T.RSC8 12305 with a different firmware. Ended up with low LED brightness and a reverse video (picture is upside down). Did switched the U16 eeprom chip and got brightness and video back to normal.
After a few weeks of testing, the problem came back. Went back to the original board with eeprom from the purchase one. Has been three weeks +++ and still going strong. At this point, I suspect that the original eeprom is the problem.
I did correct the brighness problem with a resistor divider at ADJ on the LED board, needed 1.3V, "new" eeprom would only give .9v which resulted in low brightness.
Video is still upside down. Got the pinout for LCD connector from main board to LCD panel but have no idea how to rewire for correct video. Can someone point me in the right direction.
Here's the diagram.
Thanks in advance.
Here's the diagram.
Thanks in advance.
