Sony XBR75X850C
    Sony XBR75X850C
    I am currently trying to repair a Sony Model XBR75X850C.
    The set has the dreaded 6 blinking error lights flashing. The set tries to startup with the screen illuminating but shuts down immediately
    I have replaced the main board but no change.
    So voltages from the G4 board are within range except one anomaly.
    I keep getting a 1.9 voltage reading from pin out location CN 6402 pin 4 BL_ERR. I don’t see where I should be getting any voltage reading from this pin?
    Anyone have any suggestions/recommendations?
    TIA
    Re: Sony XBR75X850C
    The LED flashing 6 times is a back-light error I believe.
      Re: Sony XBR75X850C
      You are correct on the error code.
      I’m just wondering if I don’t have an issue with the ps board as well.
      Thank You
        Re: Sony XBR75X850C
        It's possible, it could also be the LED driver board.
          Re: Sony XBR75X850C
          I found a flow chart and it points to the LD or the G board.
          Thanks again
            Re: Sony XBR75X850C
            Anybody knows, what is a 4 blink code could be? It is for a 65X900C
              Re: Sony XBR75X850C
              one here, also suggests doing a self diagnostic might clear up some issues.
              Four blinks
              - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
                Re: Sony XBR75X850C
                Panel or LD board.
                  Re: Sony XBR75X850C
                  Possibly backlight led failure.
                    Re: Sony XBR75X850C
                    https://www.youtube.com/watch?v=DyRdHSN43Y4
                    Bad LED is more likely. Do you have LED tester?
                      Re: Sony XBR75X850C
                      4 red blinking error maybe LED driver or G board
                        Re: Sony XBR75X850C
                          Re: Sony XBR75X850C
                          Tibimakai why did you entered here with your own different problems? Better to open your own thread..
                            Re: Sony XBR75X850C
                            The six flash error code is a backlight issue. Most probably, it is a dead LED. I have the 65" version of this TV and all it took was a $0.05 LED to fix. But you really "earn" the fix, because you have to dig all the way to the heart of the set to fix it.
                              Re: Sony XBR75X850C
                              You are exactly right.
                              It's a big job for such a small item to repair
                                Re: Sony XBR75X850C
                                Hi i have the 65 inch version sony bravia with 6 blinking lights , back light error.....
                                can you give me some advice how to remove the pannel......
                                i have done a few Philips 42 inch.......
                                  Re: Sony XBR75X850C
                                  Here`s the service manual for the xbr-55x850c, same type of chasis i think. The disassembly instructions start on page 12 .
                                    Re: Sony XBR75X850C
                                    Do a forum search. This has been discussed in other threads. I started a thread on exactly this issue.
