LG Flatron L1750S - Stopped to work
    Re: LG Flatron L1750S - Stopped to work
    Thanks piernov and Th3_uN1Qu3!
    Sorry but I'm sure about the pin number, so I'll upload a picture of Q502 with what I think are the pin's numbers.
    Based on my picture:
    Code:
    pins 1 and 3: 4.29V
    pins 1 and 2: 5.01V
    pins 3 and 2: 0.72V
    pin 1 and GND: 5.01V
    pin 3 and GND: 0.72V
    Originally posted by piernov View Post
    0.74V between 3rd pin and ground then? Q502 could be bad. Try to remove Q502 and put a capacitor between base of Q503 (pin 1) and ground, 33uF/6.3V at least I would say, then check if the monitor turns on.
    Did you mean base of Q502 (pin 1)? And ground = pin 2?
    I have a 33uF/25V, is that ok?
    Originally posted by Th3_uN1Qu3 View Post
    Do you get a green light when you push the power button or do you get nothing?
    Nothing happens...
      Yes, with the positive side of the capacitor on pin 1 and the negative side on pin 2.
      Yep should be fine.
        Nothing happened...
        5.03V passing through the capacitor and even pressing the power button nothing happened.
          So you removed Q502 and you still have 5V on U501's RST pin? You could try to disconnect R535, but I'm not sure the µC will start reliably.
            No, on U501's RST pin (7) I have 0V and 5V on pin 8.
            Maybe I made a mistake in the first time you asked me the U501's values... sorry about that.
            I'll upload the U501's datasheet.
              No idea then, maybe there is an issue with U501 (dead or corrupt firmware for example)…
