Go Back   Badcaps Forums > Motherboards with Bad Capacitors > MSI/Microstar
Old 10-10-2016, 10:46 PM   #1
lorins_core
City & State: Manila
My Country: Philippines
Line Voltage: 220-250VAC 60hz
Post Msi H61M-P31 (G3) No Display. No 5v on USB...
Have a nice Day to all..
I have Msi H61-P31 (G3) No Display.
*History
-Yesterday Morning I used this Unit.okay no Problem.
i have a costumer on File Retrieval USB WD Portable Drive to rescue her Files. then the drive has been detected i run the software i used. several hours then not yet finished i decided to leave it because i will go to my home need to sleep. morning this day i try to check it. ohhh. the unit has been no display but the fan turning on then led on USB WD Portable Drive not light indicate. i try to turn off. then i turn on . ohhhh no display.
- i try to troubleshoot basic. cleaning a ram and change the psu even processor. nothing happen. but i notice 1 all usb 5v-vcc have no voltage.
- how to fix that? help
here the mobo Image
lorins_core is offline   Reply With Quote
Old 10-10-2016, 11:47 PM   #2
lorins_core
Default Re: Msi H61M-P31 (G3) No Display. No 5v on USB...
help any there...
Old 10-10-2016, 11:51 PM   #3
ant3202
ant3202's Avatar
City & State: Singapore
My Country: Singapore
Line Voltage: 230V 50Hz
Kuya...... try clearing CMOS, maybe some component has failure.
ant3202 is offline   Reply With Quote
Old 10-11-2016, 12:24 AM   #4
lorins_core
thanks to idea. already to do that not luck.
(salamat wla talaga ginawa ko na yan wal parin)
question? why dont have a 5v on vcc (USB?) do you have a Schematic
(tanong bakit? wla sya 5v sa vcc ng Usb? may diagram ka nito?)
about on component i dont know. but ithink they have one of the component parts related on usb where have problem. i dont know which is? mosfet or ui drive or south bridge?
Old 10-11-2016, 01:28 AM   #5
lorins_core
Any Update....
Old 10-11-2016, 04:37 AM   #6
lorins_core
Help....
Old 10-11-2016, 07:58 PM   #7
lorins_core
Any Update
Old 10-12-2016, 04:50 AM   #8
meritosari
meritosari's Avatar
City & State: Palangkaraya, Central Kalimantan
My Country: Indonesia
Line Voltage: 220VAC 50Hz
Try this, hope this helps
meritosari is offline   Reply With Quote
Old 10-12-2016, 08:32 PM   #9
lorins_core
Talking Re: Msi H61M-P31 (G3) No Display. No 5v on USB...
Kawan Terima Kasih. Cuba belum...
Thank You My Friend...
Old 10-13-2016, 12:52 AM   #10
meritosari
meritosari's Avatar
Walang anoman
Old 10-17-2016, 09:41 PM   #11
lorins_core
Walang anoman
Boss tidak bagus ini pdf file tidak masuk...
boss the file not open.... pdf file. any file there...
Terima kasih. Thanks you Again
Old 10-18-2016, 12:51 AM   #12
bianchi77
City & State: Western Australia
My Country: Australia
Line Voltage: 220AC
clear CMOS ?
bianchi77 is offline   Reply With Quote
Old 10-18-2016, 08:15 PM   #13
lorins_core
Post Re: Msi H61M-P31 (G3) No Display. No 5v on USB...
Originally Posted by bianchi77 View Post
clear CMOS ?
thanks
i already to do that short cmos (clear) many times
other replace cmos batt also i used tested cmos batt. not lucky
BTW: I need a Schematic Diagram co'z i recognize have no VCC (+5V)on usb.then i need to trace... Thanks
Old 10-21-2016, 02:29 AM   #14
lorins_core
Any Update.... Thanks
Old 10-21-2016, 02:51 AM   #15
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
The pdf file works ok for me im using foxit pdf reader free version.
vinceroger69 is offline   Reply With Quote
Old 10-22-2016, 04:31 AM   #16
jiroy
City & State: Beirut
My Country: Lebanon
I like to draw your attention to a common behavior on some boards , maybe due to the standard Bios settings , but i've seen such behavior many times ..
If an external hard disk is hooked to the system , the system would hang up as not able to find a boot sector from the external device ..
It might not be your case , but , it could also be ...
jiroy is offline   Reply With Quote
Old 10-24-2016, 08:52 PM   #17
lorins_core
thank for your comment my friend.
- i'll wonder why? in my story tell about happen to my mobo. then i'll try to repair. no 5v vcc on all usb drive front or back panel. and the unit have no display?
Old 10-25-2016, 08:06 AM   #18
jiroy
My Country: Lebanon
Okay , but try not to focus on the missing USB 5v , as there are no display . That means the Mobo isn't performing normal booting . I suggest looking for burnt Mosfets , cracked circuits , moisturing and rust , bulged caps ..
Next , and since you have the schematic now , you can take onboard measures trying to locate an abnormality .
One way to be sure it's not memory related issues , is to remove the memory sticks and see if a sound code error appears .
Old 01-30-2017, 05:04 AM   #19
String2016
City & State: quezon city
My Country: philippines
Line Voltage: 220vac
try to check first remove all memory and see if there is beeps
String2016 is offline   Reply With Quote
