Hi guys I have a sharp LC-40LE820X, and the main power board is a DPS-126CP B.
Back ground info, is the in-laws bought this TV new for the London Olympics IIRC, so around 2012.
When on TV function, after a period of time (20 minutes or so) the picture becomes choppy, then appears to turn off: When I try to turn it on it then has a warning similar to "service has been changed, execute auto install".
But I can display pictures from a usb on rotation for hours on end.
Given this, I suspect a power supply issue: Does this sound right? Or a tuner issue is possible I guess.
I've looked over the main power supply board, initially I only looked at the large cylinder type capacitors, none of them are bulging/split, but after dusting off, I believe the flat capacitor C7813 is cracked.
Open to advice, thanks in Advance
Aussie_Matt
Aussie_Matt
