Hi everyone
I have this problem with the PWB, it all begins with shade areas on the screen done by bad led strip, it worked for about 4 months until the tv goes off for it self, when try to power on again it just stay on for about 3 second and go off again, then throws a 1-1 blinking code, at that moment I thought "the strips just burn off" so I fully disassembled the tv and find out most of the led strips was burn. So I replaced de bad leds (almost 90) then I tested by groups of 4 by for leds for (I just have a 24v power supply) and every LED was tested and was OK.
Once I put on the strips and assembled the panel try to enter the adjustment procedure to reset the led error count, and find out this scenario:
Scenario 1: TV not turning on, not even the backlight, just solid white on center icon and solid green on main board and after about 30sec turn off for about 1 sec then solid again, and this repeats three times then throws 3-1 flash code (Initial communication error).
So I tried the CH Down and Vol+ and get solid white on icon and Main board solid Led green but nothing else, then Scenario 1.
So this what I tried:
All t-con flex cables disconnected + CH Down and Vol+: Scenario 1
All t-con flex cables disconnected + Adjustment Procedure : Scenario 1
T-Con disconnected from Main: 3-2 Flash code (similar to https://www.youtube.com/watch?v=jHjBjIaQzXc)
Voltages on L1 Anode connections With LED strip disconnected: 167.2V
Voltage on L1 Cathode connections With LED strip disconnected: 0.02V
Voltages on PD are almost perfect (verified with SpeedAdiction thread) except for a NC pin getting 2.5V this PIN is between 5v BUS and Dimmer
Just LED stripes connected + PNL_POW and PS_ON feeded: getting 167.2V on L1 but not lighting stripes.
When everything is connected I find out T-Con 12V are feeded, but after the first Flash on Scenario 1, no 12V are feed, T-TCON is turned off
There's something more, if I'm not wrong each of the 3 LED strip have 2 arrays of 32 series LED of 6V each (7030 Led) Isn't necessary at least 192v for power the entire Led strip?
Here's where I get stuck, any help would be appreciated
