Replacement for CapXon LP
    From a DLP power board. 200V 470uf, ripple is 2230mArms
    I can't seem to find anything close enough. Close enough decent quality I found was UCC EK, at 1770mArms
    diameter 25
    Re: Replacement for CapXon LP
    85°C caps allow higher current.
    look for those.
    if you can't find any ask manufacturer for advice.
    Because in some cases some 105°C caps can endure higher current but must be treated as a 85°C one in that case.
      might have found one
      https://cdn.badcaps-static.com/pdfs/...8344553467.pdf
      not sure about the leakage current though
        I've found something cheaper:
        https://www.mouser.de/ProductDetail/...mLf3dAMEETU%3d
        https://www.mouser.de/ProductDetail/...FpJyP7yEJtA%3d
        The others I've found don't seem to be available.
          zero available. and the ripple is at most 1970mArms. The one i'm replacing with is 2.2Arms
            CapXon's are fucking overrated. Just go with a quality Japanese brand and don't think of it no more.
            I had same problem when looking for some smaller Su'scon caps for an audio amp. Couldn't find a single reputable Japanese manufacturer that had a cap that met the specs of those Su'scons. So in the end, I just said, "f- this" and got some Rubycon YK and Nichicon VZ general purpose caps that were more or less close enough in specs to the Su'scons. After all, the Su'scons were GP caps too, so there's no way it could have mattered. And it didn't. The repair worked without a hitch and been working fine for a long time now.
