Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 01-14-2020, 02:50 PM   #1
Hitto
Hitto's Avatar
City & State: Italy
My Country: Italy
I'm a: Knowledge Seeker
Default Best practice for soldering a Flyback Transformer
I'm trying to solder a flyback transformer back to its board. It is quite heavy and the PCB is battered by age.
Well:
There are at least 8 solderable pins and two screws which secures (or at least on paper, please read below) the transformer onto the PCB.
This is a reference picture:
I already had to reflow some pins once.
Who do you guys think would provide the less stress for the pins?
1) Screwing the transformer onto the PCB and then solder;
2) Solder the pins and then screw the transformer
Hitto is offline   Reply With Quote
Old 01-14-2020, 02:51 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: Best practice for soldering a Flyback Transformer
screw it first
petehall347 is online now   Reply With Quote
Old 01-14-2020, 02:58 PM   #3
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I'm a: Professional Tech
Some of those pins along with land areas of the pcb will have high a thermal mass, aim for the lowest temperature for soldering if the copper lands are damaged. As a side note you need to ensure your soldering system has good thermal reserve so you are able to complete the rework in a timely manner, goes without saying used leaded solder.
llonen is offline   Reply With Quote
Old 01-14-2020, 03:06 PM   #4
Hitto
Hitto's Avatar
City & State: Italy
My Country: Italy
Would it be better to screw it first?
Old 01-14-2020, 03:15 PM   #5
R_J
City & State: ☻
My Country: Canada
Screw the flyback to the board then solder the pins.
R_J is offline   Reply With Quote
Old 01-14-2020, 06:09 PM   #6
Hitto
Hitto's Avatar
City & State: Italy
My Country: Italy
Thank you.
Having a hard time even fitting it with screws (it lays unevenly, one side with more distance between trafo and board). No wonder it developed bad solder joints.
I am afraid that everytime you move that CRT some solder points takes a lot of fatigue according to inclination angle of the monitor itself. Very strange since other monitors are just better (just solder, greater pads, not screws but sturdy plastic hooks).
Been thinking about adding grommets on one side and add epoxy on the center, between trafo and PCB, which is quite frustrating and will make it unrepairable in the future. Not to count that it takes hours for epoxy to cure.
Any suggestion is warmly welcomed.
Old 01-14-2020, 06:36 PM   #7
R_J
City & State: ☻
My Country: Canada
Is this the original flyback transformer or a replacement? Did it originally have mounting screws or was it just held in place by the pins?
It is not uncommon to have poor solder connections on a flyback, or any transformer etc. Due to the larger pins they don't always get enough solder when they are manufactured. and since they have a larger mass and do vibrate at the horz. frequency the connecions get loose over time.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
