A problem with an automotive trouble codes diagnosis device
    Re: A problem with an automotive trouble codes diagnosis device
    Originally posted by techman1025 View Post
    Hi
    Well in the device management any? Marks Showing next to the driver . If yes then you need to locate the correct driver once that is gone then you need to see why it's not communicating . Start with different cable.
    Techman1025
    Nope, for this point I actually haven't seen any since the first time I tried it, watch this video that I've uploaded on Youtube a while ago that shows everything I'm facing and for the device manager notice at first minute of the video at 00:42 that there's a drive known as (I+ME Actia XS Device) with no marks next to it !
    https://www.youtube.com/watch?v=JYkhgXAk_v4
      Originally posted by petehall347 View Post
      elm thing is a joke .. ross tech is good as does programming but only for vag group .am looking at trying a Delphi for use with laptop pc next .
      Clone Passthru is not bad at all as well, just giving You an advice to purchase the 2011 version and get some rework done on it for a stable and quick performance in a addition to a hex dump for the latest software version for PIC chip on the board and You're good to go !
      Need more on that, talk to me and I'll give You the full guide.
        On scale from 1 to 10 what's Your rating for my English till now ?
          i want one i can simply install the software and use the device just like the ross tech one i have .
            I understand, You want no complication right ?
              as little complications as is possible . and late version . up to say 2016 should be fine ,i do have an all in one scanner but only a cheap launch viii that sometimes tells lies giving me codes for things that are not even fitted to the cars . and incorrect voltages and sensors output values ,
                Launchs are actually known to perform better with asian manafacturers, for European and American cars You'd better go with Autel such as (MS906 - MS908).
                  i dont have that sort of money .even if i had i would no way make it back .
                    Could the usb cable be the reason behind it ? it's 4 wires black (ground) - Green (Data +) - White (Data -) - Red (5V).
                    My idea is to replace it with a Printer cable and have the red wire disconnected as this dude did before as mentioned in this link: https://cartechnology.co.uk/showthre...light=fantomel (Post #34).
                      can't read that post. login required.
                        after looking at the ds150e clones that look very similar some are reporting they wont work on 64 bit systems . maybe it could be that and needs 32 bit .
                          Here is my China unit, I chopped the original cable off and used an old printer cable, its been working OK, sometimes very slow connecting.
                          I will change the small parts on the PCB to see if it helps, will the CTX50-1P be OK or is it best I change it ?
                          Said that guy I told about.
                            I've kept it in mind as the vendor instructs to install it on only 32 bit OS.
                              So you are using the serial port on your computer now?
                                I mean the modern printer usb cable !
                                  o.k. so you have to have a bad cable or a bad USB port on the OBDII device then.
                                    no, he cut the red so the computer does not power the device.
                                    it's possible that it overloads some laptops - a desktop would have unlimited current.
                                      then that would be good anyway no matter I kept the red wire or cut it ?
                                        and how does this programmer power up without 5V and only have the GND, Data - and Data + connected? I don't understand that.
                                        Interesting to see if there is a short between 5V and GND on that circuit board?
                                          will power up from the cars obd port
