HP elitebook 840 G3 pass
    Re: HP elitebook 820 G3 6050a2822301-mb-a01
    This file it's my org backup removed
      Hi, is it possible to flash withour desolder chip? thx
        if you do not remove the chip from the motherboard you may have reading and writing errors.
          Hi, i tried desolder the chip, but i unwillingly desolder one resistor and i dont know from where. Can somebody took a photo of chip and resistors around? Thx
            HP EliteBook 840 G3 bios clean please
            Hi guys
            could anyone clean the bios password from this bin file, please?
            Many thanks
              Re: HP EliteBook 840 G3 bios clean please
              try..
                Perfect. It is working.
                Could I bother you to help me in unlocking another 2 of the same?
                This would be the second one.
                  and third
                    Originally posted by electroelef View Post
                    and third
                    try..
                      try..
                        hp 840 g3 need password remove
                        Hi guys
                        Many thanks
                          Re: hp 840 g3 need password remove
                          Use the HP Patcher - https://www.badcaps.net/forum/showthread.php?t=79956
                            Originally posted by SMDFlea View Post
                            i used first this unlocker tool but no results , no display and the fan at high speed ..
                              Because your file seems to be broken.
                                i have finished this
                                thnx friends
                                  I received an 840 G3 6050a2822301 motherboard with Manufacturer Programming Mode (MPM) active and unbranded (AMT not set). I succeeded in programming the system information but inadvertently locked the board before branding. As a result, on boot I get a message that the board is in an uncommitted state. The Bios and EC dumps are attached. Can someone either re-activate MPM mode or tell me how to brand the board with MPM locked?
                                    if it works enter the DMI information
                                    https://www.youtube.com/watch?v=9T57ktw8n3Y
                                      Thanks Poste. Interesting result when I flashed this bios. System booted and a message that system information was recovered from EC appeared. Then a reboot. On checking the system with DMI tools, AMT is now committed and ME is "normal", which is good. MPM though is locked. The interesting aspect is that the serial number and feature byte now in the bios are not the ones I had programmed before accidently locking the board the first time. So this number apparently did not come from the EC. Any idea where this serial number and feature byte originated from. System successfully booted a sysrecovery linex distro from usb, so I think the board is OK. My guess is that to fully enable MPM, both the bios and EC need to be fully clear, but doing this is beyond my knowledge and not sure I want to take any chances since the board is now appears to be OK.
                                        HP EliteBook 840 G3 BIOS Password
                                        Hi. I got this laptop today and wanted to ask if it is possible to remove the BIOS password?
                                        It's an EliteBook 840 G3 from HP.
                                        Thanks!
                                          Re: HP EliteBook 840 G3 BIOS Password
                                          post here your locked backup bios
