This is similar to Fatal0E's thing about ABS Computer, I took off the heatsink that was on the processor because I wanted to reduce the temperature of the processor (The HP case is tiny and cramped) a bit and when the heatsink was removed I saw the plastic "Remove before use" pad. HP, leaving the "Remove before use" pad on the thermal pad of the heatsink is bad!
