Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 10-08-2021, 06:42 AM   #1
bstewara
City & State: Spring Hill Florida
My Country: USA
Line Voltage: 120VAC
I'm a: Knowledge Seeker
Default Samsung un49mu7000f dead no power
Hi.
I知 working on a Samsung UN49MU7000F that has no standby LED indicator.
No POWER
The power supply board is part number BN44-00876A
The main board number is BN94-12399A
I am stuck.
I have replaced both pwr supply and main board with no changes.
Here are some of the readings from my multi meter on various locations on my power supply
MAIN BOARD UNPLUGGED. BACK LIGHTS ON PLUG CNL802 85 volts
Backlights are all illuminated and in operating range.
MB PLUG CNM803. - UNPLUGGED
PIN 1 FAN COUNT - Open
PIN 2 ANA DIM - Open
PIN 3 A13V. - 12.89
PIN 4 OD ON/OFF - 2.163
PIN 5 A13V. - 12.89
PIN 6 PWM BLU - 2.106
PIN 7 A13V - 12.89
PIN 8 PWR ON - 1.665
PIN 9 A13V - 12.89
PIN 10 GND- GND
PIN 11 GND -GND
PIN 12 GND-GND
STB VOLTAGE TEST POINT ON BOARD 12.89. (Should read 7.5 and 11.8)
With MB PLUGGED IN. NO BACKLIGHTS.
MB PLUGGED IN CNM803 READINGS
Pin 1 FAN COUNT open
Pin 2 ANS DIM open
Pin 3 A13V 9.03
Pin 4 OD ON/OFF open
Pin 5 A13V 9.03
Pin 6 PWM BLU 34 ohms
Pin 7 A13V 9.03
Pin 8 PWR ON open
Pin 9 A13V 9.03
Pin 10 GND. gnd
Pin 11 GND gnd
Pin 12 GND gnd
STB VOLTAGE AT TEST POINT 9.03
I知 just not sure of what voltages should be reading at CNM803.
Any help would be appreciated!
bstewara is offline   Reply With Quote
Old 10-11-2021, 07:31 PM   #2
Storyteller12
City & State: Virginia
My Country: USA
Default Re: Samsung un49mu7000f dead no power
It’s the main board. If backlights work with mb disconnected that mean power board is good. You must have got a defective mainboard. Even if the panel was bad the standby light would be on when the tv is off.
Storyteller12 is offline   Reply With Quote
Old 10-11-2021, 07:33 PM   #3
Storyteller12
My Country: USA
I actually just fixed one with similar issue. It’s the eeprom on the main board causing the problem. See if you can find a replacement eeprom on shopjimmy or eBay
Old 10-12-2021, 05:55 PM   #4
bstewara
My Country: USA
I have replaced the main board with 2 different replacement boards from TV PARTS TODAY and also replaced the power supply board once with no change.
(Am I getting defective boards from TVPARTS TODAY? They’re supposed to be fully tested before shipping)
I’m a little curious to why I’m not getting the 3 VDC standby voltage.
I’m just not sure what voltages I’m supposed to be getting on CNM 803 as they aren’t marked on the PS board.
Old 10-12-2021, 06:09 PM   #5
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
The voltages and pin numbers for CNM803 are clearly marked on the BN44-00876A power supply board.
There is no 3.3 volt standby supplied by this power supply, only A13v The main board supplies all the other lower voltages.
With power removed, disconnect the two cables going to the panel, plug in tv and see if it will turn on (there will be no picture)
R_J is offline   Reply With Quote
Old 10-12-2021, 08:08 PM   #6
Storyteller12
My Country: USA
Unfortunately tvpartstoday doesn’t really know which boards are good. I’ve had several main boards from them that are defective.
Now they don’t even ask me to return them for the refund.
There prices are good and so is there return policy. So I still use them as a last resort sometimes.
I’m almost positive it’s the main board. Unfortunately they are getting harder to find for the mu series TVs.
Old 10-16-2021, 04:49 AM   #7
bstewara
My Country: USA
Thanks Much
I will try and find another MB .
Old 10-16-2021, 05:31 AM   #8
lotas
City & State: Sochi
My Country: russia
Thanks Much
If you have a programmer, then read the dump from the spi flash ic1604 W25Q40CL and put it here, I will fix it for you and you will write it back and your samsung will work.
lotas is online now   Reply With Quote
Old 10-26-2021, 07:09 AM   #9
bstewara
My Country: USA
I知 not seeing ic1604
However I found ic1603 (25q80dvsig). (1733)
Could this be the correct ic for this model?
Thanks again
Old 10-26-2021, 08:49 AM   #10
lotas
City & State: Sochi
My Country: russia
Thanks again
Do you have a mainboard BN41-02568B?
Old 10-26-2021, 08:57 AM   #11
lotas
City & State: Sochi
My Country: russia
BN41-02568B
IC901 SDP1601 ver.05 S5WWPT H1730
IC701 KLM461FEPD
IC1001,1101 K4F8E30 4HBMGCH
IC1604 25Q40CLSIP
IC1603_UT_KTN 25Q80DVSIG
IC201 AWR7GB
IC303 54627 TI 76A P42CG3
IC203,IC207 T282 2897
IC400_UT VPM1R0A 728205A
IC209,IC2301 LR1801G
IC802 10358 7271
IC801 24512FD
IC204 T21T G942
IC401_PFFU VLS1R0A 726432A
IC302 T297 5334
IC1901_CI 74LCX244 OH301
IC2302_DS 65235 TI 781 AQ9G
IC301,IC206,IC202,IC205 3201
IC1402,IC1401 18PF
Remove the radiator.
Old 10-26-2021, 10:15 AM   #12
bstewara
My Country: USA
No,
I’m sorry my main board is BN94-12399A
Old 10-26-2021, 10:21 AM   #13
bstewara
My Country: USA
I did find it!
Thanks for the photo.
Do you know if this ic can be purchased pre flashed and ready to install?
I don’t have a programmer
Thank you for all of your help
Old 10-26-2021, 10:37 AM   #14
lotas
City & State: Sochi
My Country: russia
No,
I知 sorry my main board is BN94-12399A
Why not?
Old 10-26-2021, 10:47 AM   #15
lotas
City & State: Sochi
My Country: russia
I don't know where to buy this microcircuit, buy the simplest CH341 programmer.
Old 10-26-2021, 12:10 PM   #16
bstewara
My Country: USA
Hi lotus
I just want to thank you for your assistance!
You致e been a great help!
Thank You
Old 10-26-2021, 12:26 PM   #17
bstewara
My Country: USA
Hi lotus,
I ordered a programmer I will send you the dump from the spi flash next week sometime.
Thanks again
Old 11-28-2021, 04:40 PM   #18
bdorset
City & State: Kingstown
My Country: St Vincent, Caribbean
Line Voltage: 220V 50HZ
@bstewara, Did you solve this problem?
bdorset is offline   Reply With Quote
Old 11-28-2021, 06:50 PM   #19
bstewara
My Country: USA
Sorry
No I did not.
I致e had a difficult time finding software for the ch341 programmer.
I think I知 going to try and find a pre programmed chip to install or purchase another main board.
Not sure I have the expertise to repair flashing the chip.
Regards
Old 11-28-2021, 07:31 PM   #20
hasitha prasad
City & State: Sabaragamuwa
My Country: Sri lanka
As far as I know, Asprogrammer is the best software for CH341A
hasitha prasad is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums ゥ 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
