Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 02-07-2023, 07:21 AM   #1
SR IT SOLUTION
City & State: NEW DELHI
My Country: INDIA
Angry dell e6440 no battery detected
dell e6440 la-9931p rev:1.0 battery not detected already i replace battery
still problem same. pls help thanks in advanced
SR IT SOLUTION is offline   Reply With Quote
Old 02-07-2023, 09:14 AM   #2
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
Default Re: dell e6440 no battery detected
Battery not detected will be:
1) connector fault
2) connector contacts not soldered
3) ESD diodes clamping the SMBUS circuits - remove PD2 & PD4 and test again. My bet (of a fresh box of Haldiram's motichoor ladoos) are on this fault. Killed 3 days on a macbook (other shops gave up on it) and it was down a tiny tiny SMD ESD dual didoe - needed tweezers to solder it.
See attached. Post your updates.
mon2 is offline   Reply With Quote
Old 02-07-2023, 11:06 PM   #3
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
Sometimes its a shorted cap or mosfet on discharge circuit.
mcplslg123 is offline   Reply With Quote
Old 02-08-2023, 01:48 AM   #4
SR IT SOLUTION
My Country: INDIA
yes!!!
done pd2 is faulty i remove pd2 now battery detected
thanku so much
Old 02-08-2023, 04:32 AM   #5
mon2
mon2's Avatar
My Country: Canada
SMD ESD dual didoe
DIODE. LOL, salivating while typing ☺️
Good job. The ESD diode did it's job to suppress a transient event at the battery connector. Do replace it if available.
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
