Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 02-06-2023, 03:14 PM   #1
Stephen
Meow Meow MEOW!
Stephen's Avatar
City & State: USA 🇺🇸
My Country: United States
Line Voltage: 120VAC 60hz
I'm a: Hardcore Geek
Default A1990 MacBook Pro boot looping
Did a T2 restore. Boot loops constantly then eventually loads the OS.
Did a T2 Restore and revive and OS reinstall. Same issue. Downgraded OS as well nothing.
No visible water damage seen. No burn chips and MacBook has never been worked on.
Once the OS is fully loaded seems good. For a while.
No kernel panic info shows up so definitely curious what’s going on.
It does boot fully into safe mode without issue.
MEOWING IN THE IMPOSSIBLE UNIVERSE!
Stephen is offline   Reply With Quote
Old 02-06-2023, 03:43 PM   #2
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
Default Re: A1990 MacBook Pro boot looping
Check each and every SMBUS line.
mon2 is offline   Reply With Quote
Old 02-07-2023, 04:15 AM   #3
smzlwan223
City & State: 广东省广州市
My Country: 中国
Line Voltage: 220v
205/2000
Good News and bad news! This kind of problem in my past maintenance experience, encountered a lot of similar models of similar failures, are a problem, CPU bad, BAD CPU! BGA CPU replacement perfect solution! If the appearance of the test, no problem, other measurements, are redundant!
smzlwan223 is offline   Reply With Quote
Old 02-07-2023, 05:28 AM   #4
mon2
mon2's Avatar
My Country: Canada
Good to know. From where do you source a replacement CPU? Donor board or can you share the details of a good vendor with reballed CPUs?
Old 02-07-2023, 08:30 PM   #5
smzlwan223
My Country: 中国
Line Voltage: 220v
We generally recycle chips from customers who scrap their motherboards, but we also get them from our peers. Buying them online requires a certain element of luck, which involves, sellers and buyers, IC dismantling, manual problems, and temperature control, if you don't handle it well, it will break!
Old 02-07-2023, 08:44 PM   #6
Stephen
Meow Meow MEOW!
Stephen's Avatar
Sigh it’s a i9 32GB board. Sucks this is a bad CPU or GPU.
Old 02-08-2023, 01:54 AM   #7
smzlwan223
My Country: 中国
Line Voltage: 220v
There is another solution to this problem, which is to modify the circuitry, to solve the reboot problem, but the researchers have not yet published this solution, and friends around me have learned that it is partially solved by modifying the temperature control, you can go into safe mode, view the system error log, find the corresponding point to modify the circuit! You can try... !
Badcaps.net Technical Forums 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
