Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices > BIOS Requests ONLY!
Thread Tools Display Modes
Old 02-05-2023, 10:23 PM   #361
LarryFlynt
City & State: Ontario
My Country: Canada
I'm a: Knowledge Seeker
Default Re: Microsoft Surface Pro 3 UEFI password
Hi folks,
I have a Surface Pro 3 that I can (kinda) get into the BIOS, but most of the options are greyed out. So I'm guessing that I put a password on it at some point (bought the thing used off eBay a number of years ago), but I'll be damned if I can remember what it is now. I used the fptw64.exe tool to extract the BIOS to a .bin file, but when I open the file in HXD, the location for the data I'm looking for (after "AMITSESetup") is filled with 00's. I have tried a few times, same results each time. Any ideas?
LarryFlynt is offline   Reply With Quote
Old 02-06-2023, 12:34 AM   #362
AAAC
City & State: Zacatecas, Zacatecas.
My Country: Mexico
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
@LarryFlynt
I suggest to look for the next "AMITSESetup" match (usually by pressing F3 key). Other option is to use UEFITool NE version.
AAAC is offline   Reply With Quote
Old 02-06-2023, 05:25 AM   #363
LarryFlynt
My Country: Canada
Quote:
Originally Posted by AAAC View Post
@LarryFlynt
I did that. There were three locations with "AMITSESetup", all three were full of 00's. I will have a look at that tool you suggested when I get home from work tonight.
Old 02-06-2023, 01:21 PM   #364
AAAC
My Country: Mexico
@LarryFlynt
When using UEFITool NE version, while searching for "AMITSESetup" it will give the results, clicking on any of them will take you to the UEFI variable or module where it finds a match, when working with UEFI variables it may show the DATA or show a LINK to it (Subtype column), if the variable is shown as a LINK, right click on it and select option GO TO DATA (CTRL+T).
Old 02-06-2023, 06:59 PM   #365
LarryFlynt
My Country: Canada
@LarryFlynt
Yeah, didn't have much luck there. While I could see some GUID data, it didn't appear to be enough characters for the spreadsheet to decrypt. I think I'm just going to post my BIOS dump here, and profusely thank whoever manages the magic, since they're obviously a much better wizard than I I'll still keep trying though, since I hate not being able to figure stuff like this out Thanks for your help AAAC!
L.F
Old 02-06-2023, 11:34 PM   #366
AAAC
My Country: Mexico
@LarryFlynt
When using UEFITool NE and other Hex tools you have the option of doing a string search in ASCII or UNICODE (8-bit vs. 16-bit representation, respectively), with UEFITool NE the option UNICODE is checked so you just untick the option and you are ready to find AMITSESetup variable for this BIOS (in other BIOSES you may require the Unicode option to be ticked).
Password XORED in AMITSESetup variable =
6A93842622BA584DC7E022747D07D89A332E8EC1E95444E89F 7BFA0E55A2B0350BC9665CC1EF1C83
password = 1234
Old 02-07-2023, 07:05 PM   #367
LarryFlynt
My Country: Canada
@LarryFlynt
password = 1234
Oh FFS... I definitely don't remember setting it to that! There are a few passwords I reserve for BIOS stuff, and that's definitely not one of them! Thanks so much for this AAAC! I will poke back into the .bin file to find that data, and figure out where I was going wrong.
Old 02-07-2023, 10:04 PM   #368
LarryFlynt
My Country: Canada
I could have sworn that somewhere in this message thread I saw an image that highlighted the code immediately after 'AMITSESetup', and on mine, everything right after it was 00's. In searching back through now, I see that the image showed it was the data after the 00's that was what I should have been using. If I take the data after that, which is exactly what you quoted AAAC, popping that into the spreadsheet immediately spat back that cursed '1234'!!!
AAAC, I bow to your magic Thank you again!!!
Old 02-08-2023, 12:19 AM   #369
AAAC
My Country: Mexico
@LarryFlynt
If you check the 'AMITSESetup' variable it uses 40+40 bytes for password storage, one of these 40-byte blocks is for the USER password and the other block for the SUPERVISOR password, if you see one of these blocks filled with just 00's is because the corresponding password is not set.
Old 02-26-2023, 10:48 AM   #370
Beefychris
City & State: Fredericton
My Country: Canada
Default Re: Microsoft Surface UEFI password
Quote:
Originally Posted by RethoricalCheese View Post
You can try going to recovery options by holding down shift when pressing restart. There you can open command prompt and navigate to fptw folder and try from there.
And BTW, use v9. 5 not v9
So I'm hoping I've done this correctly as Ive spent days learning how to hopefully get the right file.
Not sure I've spent this much energy on getting a password I Forgot in my life.
File Type: zip backup.zip (244 Bytes, 1 views)
Beefychris is offline   Reply With Quote
Old 02-26-2023, 10:53 AM   #371
Vesko356
Sharp Shooter
Vesko356's Avatar
City & State: Sofia
My Country: Bulgaria
Quote:
Originally Posted by Beefychris View Post
So I'm hoping I've done this correctly...
244 Bytes... No, it's not a good dump.
Try again
__________________
all donations are welcome,
Vesko356 is offline   Reply With Quote
Old 02-26-2023, 03:42 PM   #372
Beefychris
My Country: Canada
let's try again
Old 02-26-2023, 04:30 PM   #373
Vesko356
Sharp Shooter
Vesko356's Avatar
City & State: Sofia
let's try again
You have a Microsoft Surface Go 1824 right?
Quote:
Originally Posted by Vesko356 View Post
This method is not applicable for Microsoft Surface Go 1824.
https://www.badcaps.net/forum/showpo...&postcount=224
Old 02-28-2023, 07:02 PM   #374
rozpytin
City & State: kiev
My Country: ukraine
Help retrieve the BIOS password
rozpytin is offline   Reply With Quote
Old 02-28-2023, 07:32 PM   #375
Vesko356
Sharp Shooter
Vesko356's Avatar
City & State: Sofia
Quote:
Password: loomb
Old 03-02-2023, 10:03 AM   #376
SevenBIOS
City & State: Gelsenkirchen
My Country: Germany
Hi, I am new to this forum and I have the same problem. I have a Surface 3 Model 1657 with no Windows installed but there is a BIOS password which I cant remember setting.
I cannot boot from any other devices since it has secure boot activated.
If there is anyone who can help in this case maybe tell me how to dump out the bios file i would really love it. I am an absolute newbee to this
SevenBIOS is offline   Reply With Quote
Old 03-02-2023, 12:01 PM   #377
RethoricalCheese
City & State: Tartu
My Country: Estonia
Did you even try booting from windows installer?
RethoricalCheese is offline   Reply With Quote
Old 03-04-2023, 07:35 PM   #378
rozpytin
City & State: kiev
My Country: ukraine
Password: loomb
Thank you very much. Password is correct.
Old 03-05-2023, 08:47 AM   #379
boz03
City & State: bruxelles
My Country: belgium
can u give my uefi password too.
boz03 is offline   Reply With Quote
Old 03-05-2023, 09:15 AM   #380
hardware1
City & State: N/A
My Country: N/A
Quote:
Try this Password: onr3
hardware1 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
