Car USB power module 5V 8A
    How do I mount this stupid thing? It has a 2mm hole and a couple 1mm holes close to traces. M2 fits but no way I can drill that precise in a car.
    Upgrading my car USB power and can't stuff it in a box or bolt it down.
    Re: Car USB power module 5V 8A
    pcb feet.
    like this:
    https://www.ebay.co.uk/itm/10-20-50p...t/273830109355
      Thanks for sharing this
      I have been looking for something like this for awhile
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
        I thought about buying some of these but it does not look to me that it would put out 8 amps @ 5 volts
        Let us know if it really does 8 amps
        9 PC LCD Monitor
        1 Dell Mother Board
          At 8A output it heats up, dissipates around 3.5W the inductor gets hot.
          They say use use a cooling fan if you want 8A all the time. It's really good for ~5A with no problem and efficiency stays over 92% at load. It uses TPS40057 and 40A MOSFETS but at lower 100kHz. It's like a bigger KIM-055L module.
          There is a newer version V2 with a MSOP-10 IC I have not tried.
          Mine outputs 5.3V which is too much I think, so I removed a 47k resistor to get 5.1V
          Qisheng Electronics QSKJ
          QS-1205CBUM-8A V1.03
          8-35VDC to 5V 8A
          There is also a 5V 5A version (no USB jacks) that is very good for powering micros and $3, made by some other chinese company. Uses TPS40057 and flat pack mosfets.
          For mounting, tiny M2 spacers fits the small holes and a M3 in the bigger hole. I'll either mount it first to a small metal plate or try pcb feet.
            There just asking for trouble doing that
            I sure would not do it
            9 PC LCD Monitor
            1 Dell Mother Board
                I've tested it at 8A. My rule of thumb - rated chinese watts/amps, best to cut in half...
                The power components - the two AOD4184 MOSFETS are rated 40A, and the inductor Sumida CDEP-147NP-9R5MS rated 9.6A and the reverse polarity MOSFET Si4800 9A (12V input side). I drew the schematic.
                So all the parts are good enough but heat goes up under full load. The hottest part is the inductor gets hot, to ~60C at 8A so a hot sunny day would get to 75C which is too much for me.
                If I charge three USB devices to say 6.3A it gets warm but not going to croak.
                Because of cold winters I swap in polymer caps instead of the 220uF electrolytics.
                  So would you say it worth buying some on scale one ( not worth the money ) ten ( being the best thing on the planet ) what rating would you give it
                  9 PC LCD Monitor
                  1 Dell Mother Board
                    what do you want them for?
                    because you can get boards now that support QC3.0 (quickcharge variable voltage)
