Thread Tools | Display Modes |
#1 |
City & State: PA
My Country: United States
I'm a: Knowledge Seeker
![]() I have a Samsung LN46C60351FXZA that is about 4 years old. One morning I turned it on and it was working fine. About 10 minutes later, the screen went black, but the audio was still there. The TV powers on and the audio works. I can change the source of the tv and the audio stops until i change it back. There is just no picture. I have opened the TV up and all of the capacitors look fine. Any help would be great.
#2 |
City & State: United Kingdom
My Country: uk
Line Voltage: 240v
I'm a: Hobbyist Tech
![]() Pictures showing your tv parts may help you more with fixing your problem
#3 |
City & State: Federal Way,WA
Line Voltage: 120VAC 60Hz
![]() Do you see a picture if you shine a flashlight at the screen? Also, are you sure you've correctly noted the model number?
#4 |
City & State: PA
![]() Yes, it is the correct model number. I dont see anything if i shine a flashlight at the screen. I will try to get a better flashlight to test it too.
Pictures are attached. If needed i can take closer pictures of certain parts as directed. |
#5 |
City & State: midwest
My Country: U.S.
![]() can you tell if you get a menu at all?
#6 |
City & State: PA
![]() I am assuming the menu shows up as I can change the source, volume, etc. it's just a black screen.
#7 |
![]() The model number is not the same as what you posted in the thread's title. This particular model is known for having PSU/inverter issues. I'd start by checking PSU output voltages. Also, I'll wait for a definitive response as to whether an image is visible when a flashlight is shined at the screen.
#8 |
City & State: PA
![]() Sorry, it was a type, 5 instead of k!
Also, should i be able to see anything with an iphone flash light, or will i need a heftier one? I will grab a multimeter from work when i go back on Monday. |
#9 | |
![]() Quote:
![]() Last edited by capkid; 12-27-2014 at 09:40 PM.. |
#10 |
City & State: PA
![]() Then no, i did not see anything on the screen with a flashlight.
#11 |
My Country: U.S.
![]() maybe check the fuse on tcon board.
Thread Tools | |
Display Modes | |
