FIRST YOU SAID Smc_pm_g2_en 3.47V AND NOW 0 V ?????????????
DO NOT TEST VOLTAGES AT THE PINS SIDE OF COMPONENTS WHEN THEY ARE TOO SMALL , to avoid shorting two pins at the same time. use instead other testpoints.
don't check voltages at this time , i know you will never have any voltages at s3 and s0 states since s5_pwrgd is low. put your miltimeter on diode mode , and give values (line to ground ). disconnect battery and adapter to do these tests
