HP Compaq C700 says charging but isn't
    I am trying to fix the charging circuit on this laptop. Windows says it is charging but the charging icon stays at 0%. There is plenty on google about this and one user replaced PQ1 and fixed it. I am looking at doing the same but I can't tell if PQ1 or PQ2 is bad. They are N channel mosfets Fairchild FDS6675BZ. They look very hard to remove without damaging the plastic fittings nearby. Here are the readings I got with my DMM set to continuity/diode mode (I've highlighted the difference from PQ2 and PQ1 in red):
    PQ1 Results:
    All the source pins to the drains are open circuit.
    Source to gate is open circuit
    All the drains to source pins give around 0.513.
    Gate to source pins show 1.827.
    There is continuity between all source pins and the same with all drain pins.
    Drains to gate show open circuit
    Gate pin to drains is open circuit
    PQ2 Results:
    All the source pins to the drains give around 1.665
    All the drains to source pins give around 0.511.
    I would appreciate it if someone with more knowledge would have a look at this information and let me know what they think. Does PQ1 look bad or not?
    Re: HP Compaq C700 says charging but isn't
    The above measurements are in volts, according to the handbook on the continuity scale, I think. I have done more measurements using the resistance scale:
    PQ1 Results:
    Source to Drain – all open circuit
    Gate to drains – all open circuit
    Gate to source – all about 200 ohms
    Drains to gate about 1280 ohms
    Drain to Source:
    Pins 5, 6 and 8 to 1, 2, 3 are 980 ohms
    Pin 7 to pin 1 is 980 ohms but open circuit for pins 2 and 3
    PQ2 Results:
    Drain to Source:
    All drain pins show about 980 ohms to all source pins
    Does the red reading show PQ1 is bad?
    All measurements were done in circuit.
      hello my friend!
      we must focus on PU1!
      what`s the values on pin 5 and pin 7 with no battery power off/ then power on
      and with battery power off /then on
        Thanks DJ Ricoh. I'll post the results. Is it OK to leave CPU in?
          Originally posted by dj_ricoh View Post
          hello my friend!
          PU1: DC/DC Converter for charging (MB39A126PFV-ER_SSOP24) -volts
          Pin 5=ACOK and Pin 7=ACIN
          No Battery:..........Pin5/Pin7
          Power off...............0.00/0.00
          Power on...............5.00/0.18
          With Battery:........Pin5/Pin7
          Power off...............0.00/0.40
          Power on...............0.10/0.18
          Measurements taken with RAM and CPU fitted. When power button pressed the laptop booted with all lights and fan spinning.
            There's an error above. The 5.0v should read 0.0v for no battery-pin 5-power on. Can't edit for some reason.
              apparently ACIN in 0 and that should over 1.5v and ACOK needs to go in low state.
              on the left side of the PU1 there is ACIN and PACIN , try to trace that PU2A and PU3 and see why you don`t have ACIN in PU1
                until tonight I`ll make you a video how to remove that mosfet without destroying anything. ok?
                a soldering tutorial
                  Sounds great, thank you. I will try and trace those voltages.
                    OK. PU3 : LMV431ACM5X = Power Management, Voltage References = Shunt:
                    Voltages:
                    pin1...............0.00
                    pin2...............0.00
                    pin3...............1.24
                    pin4...............1.24
                    pin5...............0.00
                    There was no change to these values when the power button was pressed.
                    PU3A : LM393DG: Voltage Comparator - voltages power connected/power on (start button pressed)
                    voltages:
                    Pin1................3.29/3.29
                    pin2................1.24/1.24
                    pin3................1.80/1.80
                    pin4................0.00/0.00
                    pin5................1.24/1.24
                    pin6................1.39/1.35
                    pin7................0.12/0.12
                    pin8................19.5/19.5
                    As you can see there was no change when the power button was pressed.
                      change that pu1!
                      do you have any spares?
                        No. But I saw them on Ebay two for about $4.00 http://www.ebay.com.au/itm/360867133...84.m1438.l2649
                        Might take awhile. Will post back on results. Thanks DJ Ricoh for your kind help.
                          np sir!
                          when you tested pq1 and 2 did you took them out?
                          if not test them of the board to
