Original Xbox Replacement Caps
    Re: Original Xbox Replacement Caps
    i'm amazed the clock cap hasnt dumped all over the board - i'v worked on dozens and NEVER seen a good one!!
      you can, but these are cheaper - and tested.
      https://www.aliexpress.com/item/32909529195.html
      i recommend you select "yanwen" or "china post" for delivery - super cainiao are the chinese version of hermes!!!
      Hi ya stj
      I've been having problems with the stability of the screen on my Xbox particularly when running XBMC and notice that the three next to the CPU are bad.
      I bought the ones in the link you posted and they have just arrived. I know very little about capacitors but I'm confident I can replace them. Could you help with a couple of questions please? I got ten of them in the package so can I use the excess capacitors on the board and where? And please just confirm for me their orientation.
      Mucho gracias
        orientation, the long wire is positive,
        the painted bit is negative,
        so the painted bit goes to where the stripe was on the old cap.
        other question needs a pic of your board - there are 6 different ones
          Thanks for getting back to me, appreciate it.
          Here is a photo. Sorry not the best but I'm not anywhere my xbox at the mo. If this photo is not good enough i will have a better one tomorrow.
            Better photo.
              which polymers did you order, the 1500uf ones?
                Yes, that is correct.
                  then the picture in the last post is good to follow
                  soldering those boards needs skill btw.
                    Thanks stj, I've already replaced the three by the CPU and the problems I had are now gone. Thanks so much, I hope I get another 10 yrs out of this classic console.
                      well remember to fill the 2 empty spaces - the cpu really needs 5
                        STJ now you have polymers stuck in my head and I want to recap the whole dang board instead of 3 bad ones. I have 2200uf 6.3v, 1500uf 6.3v, and 100uf 25v all polymers in my cart on DigiKey for $25. Should I pull the trigger?
                        Ryzen 3600x
                        16GB Patriot 3600MHz
                        MSI B450 Gaming Plus
                        MSI Air Boost Vega 56
                        Acer 32" 1440P Freesync
                        Rosewill Capstone 750W
                        Hakko FX-888D Station
                        FX-8802 Iron
                        MG Chem .8mm 63/37 RA 2.2%
                          no, because it's a ripoff!
                          1500uf for the 3300 replacements
                          100uf
                          https://www.aliexpress.com/item/32832106559.html
                            100uf
                            Wouldn't Ali be a lot of counterfeit parts? Plus 4 weeks for shipping
                            Ryzen 3600x
                            FX-8802 Iron
                              shipping can be selected and is often 1-2weeks
                              they arent counterfeit, they are simply obtained in bulk - think about where all the pcb factories are!!
                              besides, they dont state the make in the add - and china makes a lot of poly's
                              the reality is that in the west we have been robbed for decades by suppliers.
                              i buy 100 high grade leds for about $2 - the western scumbags would price the same parts at 20-30c each!!
                              it's easy to see how digikey,RS, etc got so big!!
                                You win, I ordered about 40 caps from Ali. All different Poly's and even some (probably fake) Sanyo 3000uf electrolytic's for the heck of it. Thanks!
                                Ryzen 3600x
                                FX-8802 Iron
                                  the sanyo's are probably just a bit old - and with short legs.
                                  short legs is a good giveaway that they are surplus from a production line because they are fitted by robots.
                                    I found these in one of my bins I forgot I had. Any way to decipher the voltage?
                                    Ryzen 3600x
                                    FX-8802 Iron
                                      6.3v
                                      terrible lifespan!
                                        My power supply is a foxlink, should I replace the 4-5 teapo's in it? I think they are mostly 2200uf 10v
                                        Ryzen 3600x
                                        FX-8802 Iron
                                          Ok tell me something about how to know if what you are buying from AliExpress if they counterfeit or not
                                          I am not trying to be obnoxious so please do not take it that way
                                          This is the reason I do not buy a lot of items from site like this because I really do not know
                                          I have the same problem with EBay sometimes
                                          I go with the premise that the majority of items are
                                          Here is a story
                                          I bought a engraver than has a Arduino Nano Controller Board that is a nock off
                                          The only reason I know this is when I went to there to get site to get drivers and look at there Nano board I noticed that the ones I have are a little different so I researched it a little bit and found out that are a lot of nock offs out there but that not say that they work any different
                                          And yes they are lot cheaper in price
                                          The question is how do you now what good and what not good at all
                                          Capacitors are a perfect example of what I am talking about the really good quality ones and what is garbage
                                          9 PC LCD Monitor
                                          6 LCD Flat Screen TV
                                          1 Dell Mother Board
                                          15 Computer Power Supply
                                          All of these had CAPs POOF
