Latitude E6510 BIOS PASSWORD
    Re: Latitude E6510 BIOS PASSWORD
    any help please?
      Hello friend, tried my best to fix you Bios, 4MB seems good, but the 8MB Bios is totally different from the original, i didnĀ“t repair it.
      https://mega.nz/#!AgUTCQLS!EnQy1o7K4...C04Nx7C_GyRsV4
        Originally posted by gcomputers View Post
        no change password remain again , replaced with another WINBOND 25032BVSIG (the same like the original) flashed with dump without password.
        I find another chip like bios chip U35 but my eeeprom EZP2010 not detect this chip.
        i don t know what can i do i have 3 pcs from this model ?
        bro the bios chip winbond 25032bvsig / i think this bios is winbond 25q32bvsig
        tryANOTHER 25L32/ CFEON32.
          Thanks for yours answers i will try today .
            Re: Latitude E6510 BIOS PASSWORD!!!!!solved!!!!!
            hi finally i solved this bios password .
            Service tag 1F5A not have generator and need to replace service tag i find some utility but not working to me because bios is on uefi mode or not compatible with this model blablabla .............anyway
            i flashed 8MB chip that have service tag on it after passed on 2A7B with password generator entered password that generate important at the end to press right CTRL and ENTER together.
            Works fine .
              please gcomputers i also have dell latitude E5500 which service tag is #6BF7K4J-1F5A
              please what should i do to remove the bios password
                New bios dump write e5500 remove the password only soluction 1f5a not generator password.
                  Send the original file from computer
                    hi downgrade your bios with flashing chip 8mb with old dump , after that you will see your STAG changed from 1f5a to 2a7b or other model important is to remove 1F5A. After with generator password you can remove it.
                    Here is the dump A03 for your bios.
                      Please gcomputers do you mean i should first flash my bios with the one you posted for me?and then i can get the code for -2a7b service tag
                        Hi
                        You need to replace both files then you need to fix me region and dmi info upload original files and I will fix the problem .the only other way is to use the hash code generator and not the old one the newer version. $
                        Techman1025
                          Please gcomputers can you explain me the mean of 8mb chip?and also where do you get my file E5500A03.rar
                            Important if have too bios chip Ec Chip and Main chip flash MAIN BIOS
                            , if have only one flash it with that dump E5500a03 i taked it from dell site .
                            After flashing let me know.
                              GCOMPUTERS the flash didnt work.when i am doing the backup of my old bios it is giving me error.help please
                                without eeprom programer you can try this method for me (E6510)does not work , with this utility you can change service tag , try it.
                                https://community.spiceworks.com/how...spirion-laptop
                                  gcomputers,please why the dump E5500A03.rar is not working in my flashing process?i have used this file to flash my bios. Any help please
                                    I downloaded it from dell website and writeromfile from dos.
                                    i will find another dump
                                      need clean me file bios dell latitude e6510 |( la-5571p )
                                        Hello on this models of Dell laptop, the password is neither stored on any of the bios Chip but rather on the KBC chip or SMc chip and u can only bypass password by changing or reflash the chip before
                                          i attach file bios with password and without password.
                                          good bro
