Lenovo Z570 - no image
    I have 3 mb's Lenovo z570 ( 10290-2 48 44pa01 021 LZ57 )
    2 of them are auto-power on. I have only 1 vcore wich is initialy 1.1v and after ~1sec is 0.6v and after 3 sec is powering off. Bios is ok, memory 1.5v, video 1v tested with 3 processors, 3.3v and 5v are ok.
    Another mb has a strange sinusoid on video power supply. see here https://ibb.co/bdMWFs1
    Do you have any ideas?
    Re: Lenovo Z570 - no image
    rest of the coil voltages are ok ? resistance on PL4101 PL4102
    test VCC CORE VCC GFXCORE
    1D8V VGA
    3D3V VGA
    1V VGA
      Hello, after 1 year I've managed to repair one of the motherboards. Problem was PU4307 which was heating excessively, after I've removed - the pads was on fire. Changed also the PU4306 - shortcircuit between PIN 7 and PIN 8.
      Now - the second motherboard is same design as first. Next voltages are powering up: 3.3, 5v, 1.5memory.
      But I have a small problem: VCC GFXCORE isn't powering up. PU4405 has PIN2 PWM very low ~2v without oscilation. PWR_CPUCORE_PWMA is coming from PU4201 and I have allready change it, but no effects. Any idea?
