USB Voltage and Current Tester Capacity What do you think about this
    Here is something that I would like to know if anyone has one and what they think of it
    JC 100MHZ T50N Dual USB Voltage and Current Tester Capacity table with USB Current Test Cable
    http://s.aliexpress.com/BVB7n6FV
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: USB Voltage and Current Tester Capacity What do you think about this
    Pretty fancy 2.6" IPS 320x240 LCD.
    https://diykitsblog.com/obzory-i-tes...ot-100mhz.html did a teardown of one, probably older firmware. use google translate.
    RDTech Store has ones for lower cost, they instead use an app to do charting and you can buy a load as well.
      Thanks for sharing this link
      I decided to buy this one instead
      http://s.aliexpress.com/V3eeIfQF
      The UM25C and the LD35
      I bought the bundle that cost $31.69
      The Apple Application does open up on the IPAD
      9 PC LCD Monitor
      1 Dell Mother Board
        Ruideng (RD-Tech) ships stuff real fast too!!
