Msi ms-7352 post 7575 ?
    Guys,
    I got POST diagnostic 7575 and then shut off on MSI MS-7352...
    CPU Core 2 Duo E6550
    Without memory it's C1C1 repeated beep but not shut off...
    WIth RAM it's 7575 few second, two fast beep then shut off...
    Anyone knows what's the issue ?
    cheers
    Re: Msi ms-7352 post 7575 ?
    why dont u use the postcodemaster website for figuring out what the post codes mean?
      I got no clear clue from that website, looks like it's HP board...
        http://h20564.www2.hp.com/hpsc/swd/p...&swEnvOid=1098
        Is it possible that I got problem with FET, because there were some bad caps that I have replaced now...??
        FET = P09N03BDG
          How do you reckon of those FET condition ? I can not read label clearly...could it be burn and making the voltage unstable under stress ( full load ) ?
            I've replaced the FET, now it can boot, but asking for system fan...I put a fan already on that connector but still complaining and auto shut off, probably my fan is not compatible ?????
              It's fixed already, thanks guys, HP DX7400 mainboard...I'll give you a picture later on..
                Photos, I'm done with this board, now doing the test with 3Gb memory, linux and CPU E6550....
                Cheers
