Hi everybody i need UX305UA i7 6500 bios dump .from i5 UX305UA i got black screen.Original i7 bios working but have random shutdown.
Re: UX305UA i7 6500 bios dump
i5 or i7 shouldn't matter, as long as ME region is clean. Revision of the board may matter though.
Post your old dump and confirm board revision if applicable.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Hi sir
thank you for your fast reply.
i know how to clean me region but in this file i think cant do something.the only can do is download 6mb orignal bios from asus and with hex editor import it to my bin file.But still the fan is full working 4889 rpm and cpu tempratures are low 30 C degrees. i attach original biosAttached Files
hi guys.Thank you for your messages.i have tried all bios but still problem remain fan works full and have random shut downs.i dont have backup of original bios but intel managment interface driver is installed correct without exclanation mark.i also replaced the 8pin thermal ic but problem remain.motherboard is celan without water or other fluid.
But i believe it is bios related issue.
Any idea?
Originally posted by johntba View Posthi guys.Thank you for your messages.i have tried all bios but still problem remain fan works full and have random shut downs.i dont have backup of original bios but intel managment interface driver is installed correct without exclanation mark.i also replaced the 8pin thermal ic but problem remain.motherboard is celan without water or other fluid.
Any idea?Attached Files
