I picked up this TV from the recycle center . LG 55LV5500-UA. When powered on, the power indicator goes from red to white. It has no backlights and no sound. I tried doing the flashlight test and didn't see anything. I took some voltage readings with power on. Mere set to DC volts, negative lead on Metal tv chassis. See pic:
P201(supplies tuner/input board) pins aren't label, so from top to bottom:
Pin 1- 0 vdc
Pin 2. 12.02 vdc
Pin 3. 12.02 vdc
Pin 4. 12.02
Pin 5. 0
Pin 6. 0
Pin 7. 3.5 vdc
Pin 8 3.5
Pin 9. 0
Pin 10. 0
Pin 11. 24.8 vdc
Pin 12. 3.4 vdc
Pin 1- 0 vdc
Pin 2. 12.02 vdc
Pin 3. 12.02 vdc
Pin 4. 12.02
Pin 5. 0
Pin 6. 0
Pin 7. 3.5 vdc
Pin 8 3.5
Pin 9. 0
Pin 10. 0
Pin 11. 24.8 vdc
Pin 12. 3.4 vdc
