Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Old 02-28-2017, 08:08 AM   #1
TheRagnarok
City & State: Greenville, Florida
Default Zotac 980ti shorted capacitor in VRM
Its under warranty but they will not service as I bought it used from Ebay.
Zotac does not offer transferable warranties!
Anyways, I ran it at the factory overclock since Sep of 2015.
Was playing some Conan Exiles and pc just died,and I smelled that wonderful smell.
Disconnected all devices from PSU and when I plugged in the 8x pins for GPU bam, short protection kicked in.
It looks like a burnt ceramic cap.
I can replace this myself, but I am worried something else is shorted.
Question is, other than it being crappy quality what would cause it to blow?
TheRagnarok is offline   Reply With Quote
Old 03-01-2017, 05:05 PM   #2
TheRagnarok
Default Re: Zotac 980ti shorted capacitor in VRM
Well, I replaced the cap with one of the same size and color and it instantly blew on startup (a piece of ember darted out and that lovely smell returned).
I did notice that the solder they used on the card had a high melting point. Wouldn't budge with my soldering iron and my hot air rework tool almost didn't cut it either.
I'm done at this point.
1080 TI or a Vega 10 is in my sights.
Old 03-02-2017, 03:04 PM   #3
dragos2009
City & State: Craiova
My Country: Romania
Line Voltage: 220VAC 50Hz
That is because the mosfet above him is probably shorted too and send out a much big voltage and blow's the tiny cap once you apply power
dragos2009 is offline   Reply With Quote
Old 03-19-2017, 12:36 AM   #4
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Remove the cap and make sure the PCB underneath it is not charred or burned to a crisp, because that can cause arcing / partial conduction and still burn parts out.
Make sure to do this under good light. Those black PCBs are terrible to troubleshoot.
Old 03-21-2017, 08:28 PM   #5
Drack
Yup it's me
Drack's Avatar
City & State: Carabobo
My Country: Venezuela
Line Voltage: 110v 60hz
Is sad to see such a nice (and new) card Dead...
Drack is offline   Reply With Quote
Old 04-01-2017, 06:28 PM   #6
momaka
momaka's Avatar
My Country: U.S.A.
It is. But that's how stuff are just built nowadays - if it lasts past the warranty, consider yourself lucky.
I saw a faulty 980ti A few weeks ago at my job as well. It had red artifacts all over the BIOS screen and would crash when Windows 10 loaded the drivers. Perhaps it can be fixed with a reflow, but unfortunately where I work, we don't repair components - we simply replace them with whatever is equivalent. So that card is likely going to the recycling bin (i.e. crusher for metal recovery )
Old 07-11-2017, 11:14 AM   #7
mikkhh
City & State: Estonia
My Country: Estonia
I have seen 2x 980 ti with burnt gpu chips and every phase for memory and gpu was shorted. I have seen artifacting gtx970 too with red artifacts. Seems quite common for them, crashing when drivers installed seems to be a gpu chip issue.
I have even got one rx480 8gb in my hands with shorted out 12v from pcie connector, the gpu resistances seem very very low for me.
I have got multiple artifacting r9 290 cards due to faulty ram issues.
to repair this gpu the faulty mosfet needs to be isolated and removed from the board and if there are no shorts anymore on the board the gpu can be tested and if it displays image the mosfet should be replaced and it hopefully lasts a long time.
mikkhh is offline   Reply With Quote
