Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 09-15-2013, 05:25 PM   #741
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: the gutless, bloated, and fried power supply hall of shame
Originally Posted by DeanCollins View Post
hmmm can I get a second confirming that its just glue?
That sucks as it is the only obvious thing I can see.
Looks very much like glue to me. They typically use glue on big capacitors and other large parts during assembly.
Many times a fault is not visually obvious. Capacitors can also dry out, causing the same failure but no visible signs. Only way to check for sure is with an ESR and capacitance meter.
-David VanHorn
Agent24 is offline   Reply With Quote
Old 09-15-2013, 10:07 PM   #742
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
Glue/RTV is also used for mechanical stability under shock and vibration.
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 09-16-2013, 04:21 PM   #743
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
Originally Posted by Pentium4 View Post
Same picture as in the badcaps photo gallery
They have the Fairchild F, with no dash through the F and they just look cheap. I will post a picture of them later tonight
Ahh yes, I have seen those! I pulled a pair of 13007's and 13009's out of a pair of YueLin YLP-013's. I just called them "Jairchild" as I could not find any manufacturer information.
In fact, I just found them:
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 09-16-2013, 07:59 PM   #744
Pentium4
CapXon Be Gone
Pentium4's Avatar
City & State: WA State
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Mine actually look different though, I couldn't for the life of me get a good picture of them with my phone but this is the best pic I got
Buy quality, and you only cry once
Pentium4 is offline   Reply With Quote
Old 09-16-2013, 08:01 PM   #745
ben7
Capaholic
ben7's Avatar
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
They are definitely fairchild parts you have there.
Muh-soggy-knee
ben7 is offline   Reply With Quote
Old 09-16-2013, 08:07 PM   #746
Pentium4
CapXon Be Gone
Pentium4's Avatar
It's weird though, the one you can't see on the left has a different style F than the one on the right.
Old 09-16-2013, 08:10 PM   #747
ben7
Capaholic
ben7's Avatar
Like this one? That is a toshiba made transistor.
Old 09-18-2013, 07:38 PM   #748
Pentium4
CapXon Be Gone
Pentium4's Avatar
This thing came in a case. CWT, you should be ashamed! This thing is so bad. No input filtering, 330uF input caps (They're actually 220uF) 13007's, one of the smallest main transformers I've seen in an ATX PSU, 16A for 3.3V and 5V. 10A for 12V. hardly any filtering, tiny output coils. Look at the grounding wire for the transformer This thing is just horrible.
Old 09-18-2013, 07:44 PM   #749
dmill89
City & State: Harrisburg, PA
Surprisingly the Sun-Pro built Thermal Master's are actually built better.
http://www.badcaps.net/forum/showthr...Thermal+Master
CWT really should be ashamed.
dmill89 is offline   Reply With Quote
Old 09-18-2013, 07:48 PM   #750
Pentium4
CapXon Be Gone
Pentium4's Avatar
Yeah, you won't hear this anywhere else: "The Sun Pro is built better in every way!"
Old 09-18-2013, 09:02 PM   #751
c_hegge
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
I presume it came out of a CoolerMaster case. In which case (pun intended), they too ought to be ashamed.
c_hegge is offline   Reply With Quote
Old 09-18-2013, 10:16 PM   #752
Pentium4
CapXon Be Gone
Pentium4's Avatar
Yes you are right. What do you think it could do? I think this is a rare instance where the transformer would saturate before the 13007's would blow LOL
Old 09-19-2013, 06:43 AM   #753
PeteS in CA
Very shortly before, I would add. That said, wh-e-e-e-e-ere's the BEEF? There's hardly any there, there. 250W would be pushing your luck with that one. At least it's light ...
Old 09-19-2013, 07:47 AM   #754
lti
lti's Avatar
City & State: Windsor, Colorado
That might be even worse than that 420W Okia (also built by CWT).
lti is offline   Reply With Quote
Old 09-19-2013, 07:49 AM   #755
Agent24
I see dead caps
Agent24's Avatar
That design seems to be popular... I've seen it in ColorsIT and Excel PSUs too, 120 and 80mm fan versions.
Old 09-19-2013, 02:46 PM   #756
Pentium4
CapXon Be Gone
Pentium4's Avatar
No beef! It's funny because if every one of the rectifiers on the 3 main rails was pushing their rated amperage, it would be just a hair over 250W
Might be...at least this one has two toroids!
Were they CWT as well?
*general question* How come fast recovery rectifiers tend to have a higher peak repetitive reverse voltage compared to schottky's? Or is this not something that is very important if you were to replace a fast recovery rectifier with a schottky?
Old 09-19-2013, 03:17 PM   #757
c_hegge
c_hegge's Avatar
I'd give it 200W without blowing up, but nothing at all with the ripple in spec.
Old 09-19-2013, 05:48 PM   #758
lti
lti's Avatar
The Okia had room for pi filters on all outputs and didn't have that one random strand of wire coming out of the transformer for grounding. How is that supposed to work?
Old 09-19-2013, 06:39 PM   #759
PeteS in CA
I was going by the heatsinks, and was a bit over-generous, maybe. I considered guestimating 235W, a common rating back in the late 90s.
Old 09-20-2013, 11:54 PM   #760
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Please double-check tell me this really is NOT the grounding wire! If it is, it would be absolutely ridiculous. Maybe a bad joke on CWT's part?
Also, notice the text under the warnings on the label.
"As sealed stick was removed,..."
Hilarious!
IMO, that main traffo won't handle more than 150W. Come on, it's the size of a quarter!
