HP Mini doesn't work with battery.
    it gives display without battery and works well.
    but when i connect the battery the pw led blinks and the fan starts (for 3 seconds) and stops again n again. even if i connect only the cmos battery it will not run.
    what to do? Please advice.
    masud.
    Re: HP Mini doesn't work with battery.
    Check the mosfets around battery charge controller and check for broken capacitors
      all mosfets are ok and not finding any bad cap.
        There is anybody who have solved this issue?
          have you tried using another battery?
          try checking charging IC...
            have you tried using another battery? could be a faulty battery.
            _________________________________________________________________
            Free Computer Service!!!!!!!!!
            If We canĀ“t Fix the problem.
