Hi guys
I have a a EU40F6400 TV and when I was watching a movie suddenly image became black, but sound was ok. After restart, same problem, and I noticed that the power LED was blinking 5 times at startup before shuting down (but sound still present when I press the remote control).
Then I have open the TV to look at the PSU, ref BN44-00622B.
Both fuses are tested ok. Relay is ok.
No traces of any damage on both board faces.
All the capacitors seems like new !
I get the schematics here :
For the moment, I have checked the voltages on the backlight connector (and directly on the output caps). This is what I measure :
C9154 : 40V (schematic specify 43V)
C9254, C9354, C9454 : 95V (schematic specify 85V)
Same measurements with either the backlight cable connected or not.
I'm not sure if I should order a new PSU (100 euros) or not. Since caps are ok (voltages measures on all others caps seems valid, approx 5V and 12V respectively), what kind of failure could I suspect ? Would it be possible that the error come frm the backlight ? It should be wired because it seems to have 4 backight power lines, all the sections failing at the same time is unusual...(but I'm not sure of backlight composition).
Thanks !
Aurelien
Thanks !
Aurelien
