Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 08-14-2010, 08:45 PM   #141
bigcape
Not new at it!
City & State: Austin, TX.
Default Re: List of Bad Cap Manufacturers
Originally Posted by ratdude747 View Post
you should poly mod it... start a new thread on it, post some cap values there, and we will teach you what to do tho fix that.
Start a new thread where ratdude747?
The master at blowing away MBR's and replacing Seagates!!!
bigcape is offline   Reply With Quote
Old 08-14-2010, 09:43 PM   #142
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Or add to the last Dell 470 thread.
http://www.badcaps.net/forum/showthread.php?t=5974
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 08-14-2010, 09:45 PM   #143
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
didn't know there was a thread already... facepalm
HEY! POST #3600! whee!
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 08-14-2010, 09:48 PM   #144
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Originally Posted by japlytic View Post
May we add JUNZL units to the bad list? I found one bulging in a set-top box.
Have a pic?
Old 08-15-2010, 03:55 AM   #145
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
yup. the 470 is a rebadged easybake. they will cook almost every good brand due to the heat.
btw, mac g5's do that too (hence the poly kit). too hot to handle.
Uhh, don't talk shit about stuff you don't know?
The Precision 470 is not some kids system, it is a workstation system
It has excellent cooling, hell, if you want to populate all RAM slots it will even force you to buy an extra fan for that!
This system with failed Rubycon capacitors has some issue, either broken fans, broken PSU or non genuine Rubycon capacitors, it would never be able to cook genuine Rubycon capacitors if working properly
Old 08-27-2010, 11:52 PM   #146
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Just in; Silicon Chip September 2010: bad JFD units in an 18-month old HD set-top box. It was on top of a DVD player in an enclosed entertainment cabinet.
japlytic is offline   Reply With Quote
Old 08-28-2010, 03:12 AM   #147
markotech
alot of TV set has more of this bad caps,could it be the manufacturers are also the bad guys
markotech is offline   Reply With Quote
Old 08-29-2010, 08:08 AM   #148
shovenose
Send Doge Memes
shovenose's Avatar
City & State: Fairfax, California
I'm a: Forum Junkie
are XICON caps any good? blue with black lettering. thats what most of the ones at the local electronics store has. i recapped a cheapo powmax 450w with them (only 2 in that psu were bulged so i replaced them and the one other of the same specs) and it seems ok...
Sierra: Core i5-7500, 16GB DDR4, 480GB Crucial SSD, RX580 8GB.
Colorado: Athlon 760K, 8GB DDR3, 120GB Kingston SSD, RX560 4GB.
Silverado: Core i3-2120T, 4GB DDR3, 60GB Kingston SSD + 4TB Seagate HDD.
Canyon: Core i5-3470, 16GB DDR3, 120GB Crucial SSD + 500GB WD VelociRaptor HDD + 6x 8TB WD Red HDD.
Plus a bunch of ThinkPads.
shovenose is offline   Reply With Quote
Old 08-29-2010, 08:53 AM   #149
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
XICON are not low ESR.
If you put that PSU on a scope you'd be scared.
Old 08-29-2010, 09:02 AM   #150
shovenose
Send Doge Memes
shovenose's Avatar
I'm a: Forum Junkie
uh-oh...so it was an idiotic idea to give it to my friend ???
hes running a p3 off of it
Old 09-04-2010, 10:38 AM   #151
seanc
City & State: Cambridge, UK
I was investigating a problem with my washing machine today.
The PCB has 4 Capxon on it, whoopee!
Seems to be happily running through its wash cycle at the moment (thank goodness). I may replace the Capxon later.
seanc is offline   Reply With Quote
Old 09-04-2010, 01:37 PM   #152
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
For a P3 it'll work.
Th3_uN1Qu3 is offline   Reply With Quote
Old 09-04-2010, 01:45 PM   #153
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
No, they won't. - At least not for long.
Good chance they will fry out the VRM on the motherboard before they go out themselves.
Old 10-05-2010, 05:45 AM   #154
Fraser
Thumbs down Re: List of Bad Cap Manufacturers
Surprisingly from a high value Belinea flat screen (10 20 30):
Almost all caps on the controller board and the 1000 PSU cap.
- All the TEAPO (No surprise)
100 * 6
330
- All OST
470
330
- All Eltec (Eltoc ?)
1000
Fraser is offline   Reply With Quote
Old 11-12-2010, 06:55 AM   #155
EJT
I have done a recap of my Marantz CD10, I found 4 Rubycon Black Gates in there which were leaking....
They were 15 years old
Are they crap or not?
Anyway I put Pan fc in there
What about Multicomp?
I read in a post here that they are not low ESR...
But are they crap or not?
I may want to put 2 100uF / 6.3V bipolar in a protection circuit of an amp
Usually there's no voltage on them only when the protection starts working
EJT is offline   Reply With Quote
Old 11-12-2010, 08:45 AM   #156
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Just old and heat eventually got them.
Multicomp = multiple companies = generic.
Most likely Chinese junk.
Bipolar are used when the polarity changes in operation.
A low ESR bipolar would be rare if any even exist.
Both sides of the aluminum foil have an oxide layer [dielectric].
Using them in a circuit that doesn't reverse polarity will eventually erode [remove] one of the oxide layers effectively turning it into a polarized cap.
Old 11-12-2010, 01:47 PM   #157
EJT
Ok
But there has to be a reason for choosing this type of bipolar cap
It's the protection of an Accuphase power amp
Knowing Accuphase....
For now I put in 2 Pan fc's
Not entirely good but it'll work until I find good bipolars
The old ones were Elna... 20years old or so and leaking
But it won't be Multicomp
I saw a few Nichicons at Mouser
I just hope they're the same quality like Pan fc
EJT
Old 11-12-2010, 04:41 PM   #158
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Ok
Without seeing a schematic I can't tell you why it's there.
Old 11-12-2010, 06:15 PM   #159
japlytic
japlytic's Avatar
I'm a: Hobbyist
In an old TV set (late 80s) was a bad DIACON bipolar electrolytic used for coupling of the horizontal yoke.
Ever heard about this brand of capacitor?
Old 11-13-2010, 02:12 AM   #160
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Couldn't find DIACON.
Possibly a defunct brand.
