having zsustain issues with this one. Powers on no pic. Blown fuse on the zsus board. I was happy to see this no name tv chock full of lg components.
I pulled the hybrid to get the # of it assuming it was bad( dead short between 5v and ground)
after the hybrid was pulled the short remains. a quick check of the hybrid finds no shorts- this hybrid might actually be o.k....
I pulled some diodes, same.. lifted the leg on one smd cap that was smashed- same.
where do i go from here? something is pulling down the 5v man..
also i did check the smd transistors and no shorts there either. I suspect one of those smd pwm ics the question is which one do you suspect?
