Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 03-26-2020, 01:15 PM   #1
ajshoe
ajshoe
City & State: cincinnati, ohio 45215
My Country: usa
Line Voltage: 120VAC 60HZ
I'm a: Hobbyist Tech
Default samsung dryer control board
have a Samsung dryer model #DV45H7000 with no heat. problem is control board - has a bad diode. can't figure out what type of diode it is or what to replace it with. control board is part #DC92-01626B - diode is D18 on board (under magnifying glass looks like W2). If anybody has a replacement that will work - thanks.
ajshoe is offline   Reply With Quote
Old 03-26-2020, 01:37 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Default Re: samsung dryer control board
something like this?
https://www.mouser.com/datasheet/2/3...06-1138408.pdf
CapLeaker is offline   Reply With Quote
Old 03-26-2020, 02:15 PM   #3
ajshoe
ajshoe
My Country: usa
Thinking could use a 4007 ? Just tirns on 12v relay.
Old 03-26-2020, 02:47 PM   #4
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
the 1n4007 isn't high speed switching, but a 1n4148 is.
Old 03-26-2020, 04:04 PM   #5
ajshoe
ajshoe
My Country: usa
on diode test with volt meter:
D14 open .56V
D18 .24V .24V
D20 open .56V
I'll put a 1n4148 in place and test it. thanks
Old 03-26-2020, 04:34 PM   #6
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Knowledge Seeker
D14 is the snubber diode (1N4007 will do), as you can see, it is connected in parallel with the relay coil.
I cannot see how D14 and D18 are connected in the circuit, if they are also snubber diode for relay coil then 1N 4007 will also work.
BTW, you test these relay coil snubber diode in circuit, you will get false reading due to the DCR of the relay coil which is connected in parallel with the Diode.
__________________
budm is offline   Reply With Quote
Old 03-26-2020, 04:48 PM   #7
ajshoe
ajshoe
My Country: usa
Turns out that diode D18 is good out of the circuit. Ohms out like a 1n4148
Old 03-26-2020, 05:43 PM   #8
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
i guess you have to dig deeper... that wasnt it.
Old 03-26-2020, 06:01 PM   #9
petehall347
City & State: worcester
My Country: United Kingdom
will test bad on board with it being in parallel with the relay coil .
petehall347 is offline   Reply With Quote
Old 03-26-2020, 06:17 PM   #10
ajshoe
ajshoe
My Country: usa
hate these control boards ! whole story on this - heater coil relay was bad on board( dryer turned on - tumbled, no heat. after diagnostics, realized the heater relay contacts were bad. took some time but I pried control board out of the plastic shroud that it was "glued or epoxied in" and possibly ruined a trace or twisted the board which could have broke a trace of solder connection. replaced bad relay with new one - now the motor doesn't turn on. That glue was nasty - like rubber cement. I did find a broken trace - repaired it. still no motor turn on. tomorrow - i'll check solder connections around relays.
side note - I have a second (good) control board and with it installed - dryer works perfectly
Old 03-26-2020, 07:13 PM   #11
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Do you have any voltage on the secondary output capacitors of of the switching power supply board
Because it has a TNY277 it looks like I have found a few of this type of switching power supply regulator going bad or just plan bad
When I see this type of switching power regulator I just replace them if I am having problem with the power supply
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 04-06-2020, 03:46 PM   #12
ajshoe
ajshoe
My Country: usa
turns out nothing was wrong with control board except I scratched some traces on board when removing gunk around components. Samsung has some of the worst documentation on their products. turns out there was a contactor broken on the motor contacts. These contacts tell the control board the motor is running and then enables the heater circuit to turn on. anyway - dryer works perfectly now.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
