Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 02-20-2020, 11:37 AM   #1
clearchris
clearchris's Avatar
City & State: San Antonio
My Country: United States
Line Voltage: 120v 60hz / 240v 60hz
I'm a: Hardcore Geek
Default Anyone build their own equipment? Plans for small benchtop power supply.
I knocked this together with a 3d printer, some spare parts and a broken laptop power supply.
Anyone build anything useful?
https://www.thingiverse.com/thing:4126979
clearchris is offline   Reply With Quote
Old 02-23-2020, 09:17 AM   #2
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Default Re: Anyone build their own equipment? Plans for small benchtop power supply.
I am thinking about doing something similar so I can use my battery tester on BMS balancing protection boards
But have not figured out or decided how and what parts to use and how do the voltage and current limiting parameters yet
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 02-23-2020, 09:23 AM   #3
sam_sam_sam
My Country: USA
Attachment 207591
I send you a Pirate Message
Old 02-23-2020, 04:26 PM   #4
sam_sam_sam
My Country: USA
Yes many years ago I had built an adjustable bench power supply
It was not fancy but it worked I still have it but I do not use it anymore because I had burnt out the voltage regulator that I had used in it and now you can buy them cheaper than building one
It will also depends on how you answer the question I sent you to how I am going to put this together
I have comment you did a very nice job with the case and the write up about it
My thinking is that I want to use a 48 volt / 24 volts
( with a selector switch for the two different voltages ) switching power supply and a buck converter and a shunt less amp voltage meter module
With a electronic fuse controller setup that I have that I bought several years ago that I have not had a use for it until now
Old 02-23-2020, 10:18 PM   #5
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I'm a: Professional Tech
I used to build some of my own test equipment, mostly small bench PSU(s) the odd esr / capacitor tester, rf sniffers, noise sources and probes but to be honest I predominantly look at his pragmatically these days and reached the conclusion it was not worth my time. Most of my workshop purchases would not lend themselves to home-brewing and since most if not all or my electrical engineering buys are second hand and or intended for refurbishment the overall costs are low compared to new equipment.
Perhaps if there is some oddity that I need urgently which is not available off the shelf either second hand or new, and or at a sensible pricing structure then I might opt for design and home build. However factoring in my commercial rates it rapidly becomes far cheaper to purchase through the second hand circuit, furthermore equipment purchases are an investment and usually pay for themselves after a couple of repairs.
llonen is offline   Reply With Quote
Old 02-24-2020, 01:38 PM   #6
clearchris
clearchris's Avatar
I just do it for funsies. If I were a professional, there's no way I'd be building my own equipment.
Next on my list is probably an isolation transformer.
Old 02-25-2020, 09:48 PM   #7
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Nice work, clearchris! That 3d-printed case looks pretty neat.
I've been meaning to build my own bench power supply for years now, but still haven't. The problem is I always find a way to test whatever I am testing without the need for a bench PSU eventually. Either that, or I look through my boxes (note the multiple) of power adapters and always find the adapter and voltage I need... or usually something close enough that I can drop down with a diode or two and get the right voltage I need. Sure a bench PSU would have come handy on many occasions. But in the end, I've always been the type to try and troubleshoot with the least amount of tools possible, and so far that hasn't really stopped me much for fixing a good deal of stuff.
Old 02-27-2020, 04:48 AM   #8
sam_sam_sam
My Country: USA
When you do this project please post it
Old 03-05-2020, 05:20 AM   #9
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'd think an isolation transformer wouldn't be very much more than just getting an isolation transformer...
Unless...
eccerr0r is offline   Reply With Quote
Old 03-07-2020, 09:16 AM   #10
clearchris
clearchris's Avatar
sam: it's not hard, you can either get two identical transformers and hook them up, or you can have one transformer, take out one of the coils and rewind it so that it's a 1 to 1 transformer. I have one microwave transformer, I'm on the hunt for another. I'd rather not do the wrapping. Yes, in my box there would be the presence of very high voltage, but I also use microwave ovens and neon signs, both of which have similar voltages. I plan on putting it in a wooden box with no fasteners penetrating all the way through the wood. If I'm feeling really paranoid, I have some glass tubes I can use to isolate the high voltage connections.
There are plans out there for such things.
Old 03-07-2020, 09:21 AM   #11
clearchris
clearchris's Avatar
Oh, I forgot about this, I did print a case for my lcr-4. It's not my design, and it's pretty rough because it was printed before I really had my printer dialed in, but it's functional enough, if not aesthetic.
Old 03-10-2020, 07:12 PM   #12
momaka
momaka's Avatar
My Country: U.S.A.
Attachment 208383
I like it!
As for making the case smooth - I've seen people make their own "hot acetone baths" particularly for making 3D-printed ABS plastic projects shiny / with a mirror finish.)
Me - I'm more about function over looks, so I haven't even been bothered to make a case for my T4 meter.
Old 03-29-2020, 06:33 PM   #13
clearchris
clearchris's Avatar
Yeah, sometimes I smooth my ABS prints, but not often. Here are some things I have cranked out (designed and printed) in the past few days since I have been trapped. IMHO, the designs are pretty slick and the printouts are damn nice too. They are both ABS, neither have been acetone smoothed.
Raspberry Pi Zero W Case and Mount
https://www.thingiverse.com/thing:4249306
4 Module Relay Case / Mount
https://www.thingiverse.com/thing:4245641
Old 04-11-2020, 07:26 PM   #14
clearchris
clearchris's Avatar
New design. CCM5D PWM motor controller. First thing I'm going to hook it to is a computer fan for a fume extractor. No more getting buzzed off kingbo fumes for me!
Pretty simple design, also helped that I used a lot of the design from the power supply.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
