Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 10-04-2017, 03:48 PM   #1361
jazzie366
City & State: New York
My Country: United States
Line Voltage: 110v, 60hz, and a Variac.
I'm a: Hobbyist Tech
Default Re: the gutless, bloated, and fried power supply hall of shame
Originally Posted by Wester547 View Post
CRT TVs / monitors arent nearly as hard on their caps as LCD TVs / monitors are.
Heh, its only 3 years old. The real test of any bad cap is time.
One could also chalk that up to the inconsistency that is characteristic of many bad crap brands.
Inconsistency true, but seeing as they've been the same for so long, and that the datasheets haven't changed in ages other than for looks I'm not buying it.
They may not be as hard on the caps, but then there's people like Samsung that used them. One might argue KSC branded caps are bad, meanwhile Apple also used them in their PSUs, just opened one from over 10 years ago recently, the caps are all KSC and doing fine. Same can go for Beryl, Lscon, Su'Scon etc. I blame the manufacturers more than anything.
Popcorn.
jazzie366 is offline   Reply With Quote
Old 10-04-2017, 06:13 PM   #1362
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
That's exactly the problem with crap cap brands - some will run 10+ years and some will die in a year or less.
Yes, it is important how the cap is used in the device and if abused by heat, excessive ripple, and whatnot. But still, I have seen way too many crap cap brands last only a little bit in one device and much longer in the same model device - particularly in PC PSUs. So I still rather avoid crap cap brands when possible - or at least when doing repairs for other people. For my own stuff, I often leave the device alone until a problem surfaces. Or in some cases, I replace only the caps that are most critical and can cause damage if they failed.
Old 10-04-2017, 06:55 PM   #1363
Wester547
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
I’ve seen many a failed KSC in Huntkey PSUs, the same PSUs in which Fcon and Teapo regularly blow up (along with a host of relatively unknown Chinese brands). KSC don’t always show visible signs of failure either. Yes, they may be better than CapXon, Sacon/Evercon/GSC, YEC, Stone, Rulycon/Jee, Goldlink, pre-merger G-Luxon, Jackcon, Hermei, Arcon, Chhsi, Fuhjyyu, etc, but that doesn’t make them trustworthy.
My takeaway is that such brands (and bad series) should not be used in mission critical / heavy duty applications at the very least, such as a workstation or a server PSU or motherboard.
Wester547 is offline   Reply With Quote
Old 10-07-2017, 12:31 AM   #1364
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
What? That has full wave bridge rectification? There are 4 diodes right outside the AC input.
I wasn't talking about that one, watch closely to what you're quoting.
I was talking about the one _I_ had, and prepare to wince in pain where three diodes AND the feedback circuitry were omitted for cost savings:
eccerr0r is offline   Reply With Quote
Old 10-13-2017, 01:28 PM   #1365
jazzie366
HOLYSHIT
Is that a measly 47uF smoothing cap on the output?!
Old 10-13-2017, 07:44 PM   #1366
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
noname pos at supply found in industrial equipment.
more wire jumpers than parts.
kc8adu is offline   Reply With Quote
Old 10-13-2017, 07:54 PM   #1367
kc8adu
kc8adu's Avatar
My Country: U.S.A!
what regulation?
and who cares about line/load isolation?
Old 10-13-2017, 10:18 PM   #1368
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Yeah that wall wart was a real POS. I wonder how well it'd perform if I added the missing parts...
Old 10-13-2017, 11:06 PM   #1369
Behemot
Behemot's Avatar
City & State: Prague, 504'52.22"N, 1423'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
Oh yeah baby, there's that diode treatment too
That AT unit, so some turning machine or something like that?
Behemot is offline   Reply With Quote
Old 10-13-2017, 11:20 PM   #1370
ruky con
a fake rubycon
ruky con's Avatar
City & State: california
Line Voltage: 122.5VAC 59.9Hz
Maybe you can take a look at this one and tell me if it can output 2 amps.
(this one you can't fill in the missing parts)
When it arrived i found out it was broken. (the seller is shipping me a new one for no extra cost even though i just wanted a refund, oh well)
ruky con is offline   Reply With Quote
Old 10-13-2017, 11:45 PM   #1371
Behemot
Behemot's Avatar
My Country: CZ
Maybe about an amp. I presume the blue cap is not safety-rated.
Old 10-14-2017, 12:13 AM   #1372
ruky con
a fake rubycon
ruky con's Avatar
You are right about the blue capacitor not being safety rated.
Also the primary capacitor is a fake Ymin LKL 6.8uf 400v capacitor. (Two reasons why i think the Ymin cap is fake. #1 the print on the heatshrink looks like crap and #2 the maximum temperature rating on the capacitor is "125C" when on the datasheet it says it should be 130C)
Old 10-14-2017, 12:26 AM   #1373
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
It reminded me of this, it's kinda the opposite where the PSU is fine, but just as many jumper wires
https://www.badcaps.net/forum/showpo...postcount=1039
Old 10-14-2017, 10:37 AM   #1374
jazzie366
Ive seen many a failed KSC in Huntkey PSUs, the same PSUs in which Fcon and Teapo regularly blow up (along with a host of relatively unknown Chinese brands). KSC dont always show visible signs of failure either. Yes, they may be better than CapXon, Sacon/Evercon/GSC, YEC, Stone, Rulycon/Jee, Goldlink, pre-merger G-Luxon, Jackcon, Hermei, Arcon, Chhsi, Fuhjyyu, etc, but that doesnt make them trustworthy.
Yeah, Huntkey was BestBuy's house brand right? I know currently Insignia is, and they are still using the same OEM from ages ago, still using fCon cabps in them. I know they aren't all fCon now though, some of them are Taicon on the secondary, some are fCon and they're quite large values (3300uF and 2200uF seemed to be the most common ones).
Yes, I know it doesn't make the caps trustworthy, but I'm still blaming the manufacturers of the power supplies for the failures, seeing as in other applications, albeit they were smaller, they lasted and are still good to this day. So while that might not make them "amazing" capacitors, but they're at least half decent so I'd assume if they were ran well under spec they'd be fine.
Old 10-14-2017, 10:50 AM   #1375
jazzie366
That is in fact, a fake Ymin. The vent is wrong, and it's pushed in. That's the #1 sign of a fake cap, the vent. That's a common cheapo way of putting a vent on a crap cap. They use a punching machine to put the vent in without supporting the bottom of the can, so it just presses in. This almost ALWAYS makes contact with the foil on top, so if it's a high voltage cap, the WHOLE CASE it live at mains voltage. Now, this might be true for most caps, except in this case, there is an incredible current behind it.
And the printing with the logo is wrong, there should be more spacing between it. The spec of temp being wrong is also a dead giveaway.
I'm curious as to why there are so many fakes of brands like these. One thing I've started to notice is that they all are re-wrapped. I've found knife marks and scratching on the cases of crap caps, indicating that the fakers are buying caps from someone, and then re-wrapping them.
There's a brand of cap called Orient that I'm suspicious of being behind this. I've received some of their caps from cheap china lots, and what I've seen is that they re-wrap their caps with newer wrappings on them, meaning they've taken older stock and re-wrapped it with newer wrappings to make them look new. It makes me suspicious that there's some fuckery going on there.
Old 10-14-2017, 01:35 PM   #1376
Behemot
Behemot's Avatar
My Country: CZ
Recycling is a big thing in the west, so China's just trying to catch up. So we send them ships filled with e-waste, and they try to reuse everything. Either whole refurbished and repacked boards, or at least as a spare parts. In worst case they disassemble it to the basic components and resell those. Back here OFC. They've been doing that for some time now with lithium cells. Obviously they moved forward and started re-wrapping caps too.
I bought some used MOSFETs some time ago with new electrodes stamped onto the old ones. This may actually be the cheapest way how to obtain genuine power FETs from China as they won't be faking used transistors when there is so many genuine ones going back for free. Among the new ones, if it is really cheap, 99 % of them are fakes.
Kinda makes you wonder why ppl are so dumb to send it there for free (throwing it to those like an all eco-friendly-whatever-crap e-waste bins and making some subsidised suckers rich) and than buy it back again as a „new one“ on sale from fleebay etc.…
Old 10-14-2017, 03:50 PM   #1377
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
Semiconductor companies and component distributors are going to make more profit selling next year's designs to new industry than anyone selling recycled parts to repair technicians.
Average consumer Joe doesn't know what a MOSFET is, but he can buy a new TV for $199 on sale so he doesn't care anyway.
Only people like us care, but we are not a high profit market. China makes a profit because they get all the e-waste for free (or get paid to take it) and the market is bigger than zero, so they're still not losing money and they don't seem to care about tiny profit margins (for now).
-David VanHorn
Agent24 is offline   Reply With Quote
Old 10-14-2017, 04:18 PM   #1378
ruky con
a fake rubycon
ruky con's Avatar
I just noticed some scratches on the vent like someone used a knife on this capacitor. This makes me believe that this capacitor is indeed second hand.
Old 10-14-2017, 08:43 PM   #1379
momaka
momaka's Avatar
My Country: U.S.A.
Awesome!
With mostly jumpers inside, that label sure puts a whole new meaning to "NO SERVICEABLE COMPONENTS INSIDE"
Old 10-15-2017, 01:24 AM   #1380
jazzie366
Out of curiosity, can you crack open that transformer? It looks half decent for an overall shit power supply.
