Old 03-18-2009, 01:20 AM   #1
samnabass
Default Planar PL1910M LCD will not power on
Hi to all.
This monitor has been driving me nuts for the past two days and I just can’t figure it out so i came in for some help.
The main problem is the monitor will not turn on just a flashing LED on the ON button.
The back lights were checked to be OK
All the caps checked ok with and ESR Tester.
All the diodes checked OK – Desolder one leg and test with a smart tweezers.
MOSFET Tested Ok.
Resolder all the joints on the back side.
And still no go – so I figured maybe I should try to power it from an external power adapter but there are no marking on the board to which pen is which. So I plugged in a couple of extra back lights to the board. Flipped it upside down and fired it up and start poking the bins I found the +5V / +12 / Ground / On / Of while doing that I accidentally jumped the pins marked on the attached image A&B and the back lights come on and stayed on – tried to trace the connectors to the Video board but that’s almost impassible.
All the caps on the video board checked ok too.
Any ideas ???
samnabass is offline   Reply With Quote
Old 03-18-2009, 04:16 PM   #2
mladen82
City & State: Podgorica
My Country: Montenegro
Line Voltage: 220V 50Hz
Default Re: Planar PL1910M LCD will not power on
if dc voltages +5V and +12V are fine and if are regulated voltages on main a/d board (3.3V or 1.8V probably) are fine too, problem is probably in mcu (or his eeprom) as led flashing, however check for possible shorts (smd capacitors) on main board or even shorts towards lcd panel electronics
mladen82 is offline   Reply With Quote
Old 03-19-2009, 09:12 PM   #3
samnabass
Hi, Thanks for the info - i did check as much as i can with no luck - i spend too much time on this board and i think it's time for it to be recycled.
Take Care.
Old 03-20-2009, 09:17 AM   #4
EGuevarae
EGuevarae's Avatar
City & State: Chiriaco Summit, CA - near the AZ-CA Border
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Post Re: Planar PL1910M LCD will not power on
Originally Posted by samnabass
Hi to all.
MOSFET Tested Ok.
Any ideas ???
Looks more like a Hanns-G than a Planar.... look at this thread : http://www.badcaps.net/forum/showthread.php?t=6695
Did you check the LCD without the LCD connected to the VBoard to see how the power LED behaves?
  • ASUS ROG Maximus IX Code
  • Intel Core i5-7600K 3.8GHz
  • Windows 10 Pro x64
  • GeForce GT1050
EGuevarae is offline   Reply With Quote
Old 10-08-2009, 03:59 PM   #5
stneargd
City & State: Ohio
Talking Re: Planar PL1910M LCD will not power on
If the led is flashing green and amber, the unit needs reset. I have purchased 3 of these units with this issue and all worked after resetting.
Here is the link to the reset procedure:
http://marsbox.com/blog/howtos/plana...d-monitor-fix/
stneargd is offline   Reply With Quote
Old 11-19-2009, 11:47 PM   #6
pfjoe
strneargd ... you are my new hero ... thanks!!!
pfjoe is offline   Reply With Quote
Old 10-06-2010, 08:00 PM   #7
sceva
City & State: Omaha, NE
I just fixed a Planar PL1911M with the same problem!! Thanks for the link.
sceva is offline   Reply With Quote
Old 03-01-2011, 02:40 PM   #8
DigitalStone
Same here. Thanks for the link. Wish I had found this before I took it apart.
Works great now.
DigitalStone is offline   Reply With Quote
Old 01-11-2012, 06:51 PM   #9
jfarrell
OK so this planar was fixed with a reset...amazing....
now my question is...
How many other monitors allow a similar reset, to get them going again.
( is planar the lone dog? )
jfarrell is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2019
