Old 01-30-2018, 07:55 AM   #1
nbdy
City & State: Sv.Nedelja,Bestovje
My Country: Croatia
Line Voltage: 220VAC/50Hz
I'm a: Hobbyist Tech
Default Samsung SyncMaster 223BW
Have a little problem with a 223BW samsung ...
Have changed all 5 820uF capacitors,the 330uF,and the big one 100uF/400V (with 150uF/400V)
The problem is the monitor turns off after 2,4,5,10 minutes (no rule when) ...
The power led is on,but no picture,after pressing the power button off/on the monitor works (for 2,3,6,9 minutes) ...
Example : the autoadjust pressed,and after 5-10 sec screen goes off
the autoadjust pressed, and after 30 sec the screen goes off
the power button remains on (blue)
thx
nbdy is offline   Reply With Quote
Old 01-31-2018, 11:25 AM   #2
Dumah Brazorf
City & State: Brescia
My Country: Italy
Line Voltage: 230VAC 50Hz
Default Re: Samsung SyncMaster 223BW
Check with a lamp if the image is still present.
Low the brightness at minimum in order to see if it stays on for more time.
Dumah Brazorf is offline   Reply With Quote
Old 02-01-2018, 08:26 AM   #3
nbdy
My Country: Croatia
Ok,with brightness on 0 the monitor is 20++ minutes up ....
What to change ??
Old 02-01-2018, 11:07 AM   #4
Dumah Brazorf
My Country: Italy
Probably the inverter transformer.
Old 02-01-2018, 02:50 PM   #5
nbdy
My Country: Croatia
Will try to change,thx
Old 02-04-2018, 08:44 AM   #6
djordje
City & State: Pozarevac
My Country: Serbia
As i can see you are using windows 7 and maybe this wont help you but i will say.
I had similiar problem,first i changed inverter transformer because it was turning monitor off after 5 sec, after that monitor was working same as yours 2,4,5,10 minutes.
I have found out that was problem with windows 10 and graphic drivers because i had one monitor and just switched on another.
djordje is offline   Reply With Quote
