Gateway 2100 powers up shows video than goes black I have replaced all caps but still no go. On the back of the board are 4 transistors 2 # BH 4214 (D405) and 2 # BE5G43 (D408) can someone tell me where I can find suitable replacements for these? and the spect. sheet
Gateway 2100
Re: Gateway 2100
Ok I did find the Data sheet for these mosfet They are Alpha & Omega transistors. The AOD408 is a 30v 18A N-Channel and the AOD405 is -30v -18A P-Channel The AOD408 is now AOD484 and is available from Digi-key but I cannot find the P-Channel AOD405 Is it necessary to match the data exactly What would be a suitable replacement and can someone suggest a Canadian supplier.
Re: Gateway 2100
You may have bad lamps in that one.Mann-Made Global Warming.
- Dr Seuss
Re: Gateway 2100
Originally posted by davgI never tested the lamps because it had the same symptoms as several other monitors I repaired by replacing either the caps or the transistors or both. I assume to much. Is this a common fault with this model?
My main question here is why you are changing them, did you test them and found them to be bad, or is just a standard procedure?There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
Re: Gateway 2100
I don't know that screen.
I'm just saying symptoms sound like lamps could be the problem.
Looks like you jumped from caps to IC's without checking the lamps.
According to this AOD405 crosses to a STU2030PL.
This crosses it to AOU405, CED3301, and CEU3301.
- Dr Seuss
Re: Gateway 2100
[QUOTE=PCBONEZ]I don't know that screen.
QUOTE]
Exactly the same here. You didn't tell how you came to the conclusion that the ICs were shot.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Gateway 2100
[QUOTE=eguevarae]Originally posted by PCBONEZI don't know that screen.
QUOTE]
Re: Gateway 2100
Originally posted by davgNow I have to learn how to test, remove and replace lamps. great something new.
What I did? I took an inverter from a neon light kit for a PC (dual output), soldered the output connectors of the dead PSU/Inverter on it, and installed banana connectors in the input side of it. It has a switch so I can connect the lamps and then turn it on. Here are some pics. The last thing I did was put back the inverter circuit in its little plastic case and install the banana connectors (not shown) to use with my test supply. Before the test supply, I used a power adapter for external hard drives that had an output just like the molex connectors from an ATX PSU. That's how I test the lamps most of the time.
The removal of the lamps, is another story. It varies with the LCD Panel model, and sometimes it is easy, sometimes is not. Just be careful if you remove them, as they are fragile (very fragile)Last edited by EGuevarae; 02-12-2009, 10:44 AM.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Gateway 2100
Originally posted by eguevaraeWell, I found myself in the same situation a while ago. Lucky (?) me, I had a pair of CCFLs from an LCD panel with a burned (melted, in fact) Power supply.
Re: Gateway 2100
Originally posted by davgVery creative my friend good job. What kind of voltage and amperage do these ccfl require? There must be some way to test them without removing them? Connectors is another issue of course these are different than the ones in a known good screen just my luck.
As for V and A ratings for the lamps, that is a really good question. I don't know.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Gateway 2100
oopsMann-Made Global Warming.
- Dr Seuss
Re: Gateway 2100
Voltage is like 800-1800 VAC, usually in the 30-60 kHz range.
Amps though is only like 5 mA.
- Dr Seuss
Re: Gateway 2100
Originally posted by PCBONEZVoltage is like 800-1800 VAC, usually in the 30-60 kHz range.
Just to confirm that these symptoms reflect failed lamps. The unit turns on and shows video but than goes black (on light stays green) Shine a bright light into the screen shows video. This could be among other things Failed caps, Failed Transistors. Failed lamps or all of the above???
Re: Gateway 2100
It could be all, or a combination of some, or just one..... that's why you first check visually for bad caps, then for shorts, open fuses, then the lamps with a good inverter or the inverter with good lamps, and so on ....There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Gateway 2100
Originally posted by eguevaraeIt could be all, or a combination of some, or just one..... that's why you first check visually for bad caps, then for shorts, open fuses, then the lamps with a good inverter or the inverter with good lamps, and so on ....
Re: Gateway 2100
Originally posted by PCBONEZYou may have bad lamps in that one.
Re: Gateway 2100
Originally posted by davgThanks again PCBONEZ and equevarae for your great advice that gave me reason to take a second look. While trying to find an adapter for these ccfl I discovered that one of the pins was bent. I straightened it put back together and all is well. Goes to show never be to hasty in your decisions but check all possibilities. Many many thanks
And you learned something along the process, so double benefit.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Gateway 2100
Congrats!Mann-Made Global Warming.
- Dr Seuss
