Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 09-05-2007, 02:23 PM   #21
Fizzycapola
Fizzycapola's Avatar
City & State: England
Default Re: What causes "clicking and popping noise" on Audigy cards?
Thanks for post willawake, I will consider them during my next purchasing.
999999...
Thanks for suggestions.
Rubycon Rubycon Rubycon
Fizzycapola is offline   Reply With Quote
Old 02-08-2008, 06:03 PM   #22
Fizzycapola
After reading about new op-amps in the op-amp market featuring "no pops and clicks", I think a solution may be finally feasible.
I've been looking at this aswell as other new ones came in farnell last month:
LM6171AIM/NOPB NATIONAL SEMICONDUCTOR Operational Amplifier (Op-Amp) IC New
LM6171AIM/NOPB Operational Amplifier (Op-Amp) IC 1496188 Image is for illustrative purposes only.
Please refer to product description
Manufacturer: NATIONAL SEMICONDUCTOR
Order Code: 1496188
Manufacturer Part No: LM6171AIM/NOPB
RoHS : RoHS Compliant Yes
Description
* Operational Amplifier (Op-Amp) IC
* Number of Amplifiers:1
* Bandwidth Max:100MHz
* Slew Rate:3600V/us
* Package/Case:8-SO
* Leaded Process Compatible:Yes
* Peak Reflow Compatible (260 C):Yes
* Supply Voltage:16V
Old 02-08-2008, 07:15 PM   #23
999999999
City & State: Near Cincinnati, OH
Line Voltage: 120VAC 60Hz
Fizzycapola, LM6171 isn't new, maybe just the lead free version is. Many feel bipolar opamps don't sound as good as jfet (input), though if you were wanting to directly drive low Z headphones then it's higher than average current capability would be a plus.
Regardless, when one talks of opamps more immune to clicking or popping I think it's generally in one specific context, when some of them are powering up or down (only once per power cycle, turning on or off the equipment) they have an instable voltage range below their minimal spec'd voltage. You wouldn't be seeing that problem while using a system continually turned on, rather it seems the opamp is getting this output from the sound processor due to the PCI bus problem others have mentioned.
I may be wrong, but I have built a few headamps including using LM6171. What you might do is temporarily solder on jumper wire to the opamp input pin for L & R channels and to ground, talking all three wires to an off-board headphone jack. This takes the opamp out of the loop and you can directly drive the next stage to see if the pops and clicks are already present before the opamp's involvement. Hooking this up to a scope instead of headamp or headphones would be even better.
999999999 is offline   Reply With Quote
Old 02-08-2008, 08:10 PM   #24
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Me,,
I just unplug the damned speakers...
There's a 4 foot high stack of Kenwood right behind me....
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
