Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 08-15-2014, 11:28 AM   #21
stj
stj's Avatar
City & State: Europe
Default Re: Preemptively Recap Motherboard?
Originally Posted by diif View Post
I've been looking at the ss-02 for desoldering, i like the idea of the silicone at the end to get really close to the job.
http://www.amazon.co.uk/innovative-s...ds=desoldering
just put some H30X25 hellerman sleeve on the end of any pump.
Old 08-15-2014, 11:37 AM   #22
stj
stj's Avatar
looks familiar!
http://www.dx.com/p/lodestar-l304017...-yellow-284773
this is the one sold by weller:
http://www.dx.com/p/pro-skit-8pk-366...k-green-192877
and this is a variant with better grip:
http://www.dx.com/p/wlxy-ll-101-deso...k-green-258505
Old 08-15-2014, 12:18 PM   #23
Uniballer
City & State: Buffalo, NY
The patents on the original Edsyn Soldapullt DS017 expired quite a while ago. So the new clones might be every bit as good. But I don't like the designs that continue half the tube to provide plunger protection. I have to keep shifting my grip on those to be able to work the plunger with my thumb. With the Soldapullt DS017 configuration you keep your thumb on the trigger button while you flip the pump around and press it against the bench (or your chest) to get ready for the next joint.
Uniballer is offline   Reply With Quote
Old 08-15-2014, 01:07 PM   #24
diif
City & State: Midlands
My Country: England
Thanks for that tip.
I think i'll get some next time i place an order.
diif is offline   Reply With Quote
Old 08-19-2014, 06:01 PM   #25
Uniballer
My impressions of a new GY-059 desoldering pump:
The GY-059 looks very similar to an Edsyn Soldapullt DS017. I would say that it was intended to look identical, but there are a few small but noticeable differences if you are looking for them. The plastic is a darker blue, and some parts have slightly different corners, or rounding. Barrel parts will not quite interchange with those from an Edsyn DS017; the locking tabs are a different size. I could not push out the tip from the GY-059 without removing the end cap, despite the pictorial instructions indicating this method (the cocking piston appears to be a little too short). The tip appears to interchange with an Edsyn SRT12, but it is not built exactly the same. The lettering "NO SOLVENTS OR HEAT" and "COVERED BY U.S. AND FOREIGN PATENTS & PENDING APPLICATIONS" on the side of the barrel are in a slightly different font.
Suction appears to be excellent, both by the thumb test and in actual use. The release is smooth enough that the tip does not hop around. The tip did not melt or deform when I contacted it for a short time with a Hakko FX-888D with a 3.2mm chisel tip set to 350 C. I can't say anything about long-term reliability, but while new I found the operation of this tool to be essentially indistinguishable from an original Edsyn Soldapullt DS017.
Old 08-20-2014, 04:20 AM   #26
Uniballer
It seems that the rod that cleans out the tip might be a little smaller on the GY-059, and the tip I.D. is definitely a little bigger. In any case there is a bigger gap between the inside of the tip and the cleanout rod. I haven't seen any ill effects from this yet.
Old 08-21-2014, 06:24 PM   #27
mockingbird
mockingbird's Avatar
Excellent, well-worded review Uniballer. I've been considering purchasing one of the knock-offs for some time now. By the way, the tips are made of teflon, and I've seen Chinese replacements available inexpensively.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 08-21-2014, 09:15 PM   #28
stj
stj's Avatar
teflon or not, they will melt.
put some hellerman on the end.
Old 08-21-2014, 10:33 PM   #29
mockingbird
Teflon has a maximum temperature of 300C... The tubing you're recommending has a maximum temperature of 95C according to the datasheet. How exactly will it prevent the tip from melting?
Old 08-21-2014, 11:17 PM   #30
stj
stj's Avatar
the hellerman sleeve is used slightly overhanging the end of the tip by about 3-4mm
it creates a seal to make the pump work over 100% better than before.
yes, hellerman sleeve will burn - very slowly.
first it will harden slightly, then go brown, then crack.
it takes hundreds of desoldering uses for that to happen.
and you get the sleeves in a bag of 100 or more and cut them in 2.
so it's a reasonable "consumable item" to use.
Old 08-22-2014, 01:37 AM   #31
mockingbird
Thank you, that's a very useful bit of information.
