Old 10-19-2010, 09:44 AM   #121
dell-usional
Default Re: Dell E153FPB Back Light problem - and another
top fix chap, a bit of 2 amp fuse wire done the trick. all hale brian h
dell-usional is offline   Reply With Quote
Old 11-10-2010, 04:25 AM   #122
coolcurrent
Hello, my dell flat screen too has this problem. I have read the entire post, but it seems there ins't any particular solution. Can anybody point out which transistor is causing this
thanks
coolcurrent is offline   Reply With Quote
Old 11-10-2010, 05:25 AM   #123
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
thanks
1. The problem is not caused by a transistor. The problem is caused by bad solder joints on the transformers.
2. There are two identical circuits for each inverter. Either (or both) transformer can have bad solder joints. Usually only one pair of transistors fail.
3. You need an ohmmeter to determine which transistors are shorted.
4. If you replace the transistors without resoldering the transformers the new transistors will also fail.
5. Several different boards were used in each model of the monitor. Without determining which version you have, it is impossible to give you a location number.
6. There are pictures of some of the different versions of the board in this thread. Since you were unable to identify which one you have, a picture of YOUR monitor will be necessary. See my signature for information on taking and attaching one.
PlainBill
Old 11-10-2010, 05:52 AM   #124
coolcurrent
my monitor model is E153FPb. one unique thing about mine is that you have to whop the monitor on the back, then it will come on and work just fine. then after powering off for long hours, the cycle restarts again
Old 11-10-2010, 05:59 AM   #125
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
BFD!!! I had assumed you were smart enough to post in a thread that was related to your monitor. That STILL doesn't tell me what power supply / inverter board Dell happened to use in it!!! It is easy to identify the likely defective parts by looking at the board, I know of no way to do so without opening up the monitor.
PlainBill
Old 11-10-2010, 09:07 AM   #126
coolcurrent
PlainBill
Here is the board picture
Old 11-10-2010, 09:15 AM   #127
smason
smason's Avatar
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I'm a: Hobbyist Tech
Seems obvious to me, between reading the rest of this thread, the fact that if you whack the monitor it comes on, and from that (not terribly good) picture.
BAD SOLDER JOINTS
smason is offline   Reply With Quote
Old 11-10-2010, 09:27 AM   #128
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Good grief, couldn't you make it smaller? Fortunately I was able to match it to a real picture.
Large blue circles - transformers with bad solder joints. Remove as much solder as possible from the pins and resolder
Red circles - bipolar transistors (2SC5706 or 5707). Test and replace both if either transistor in a pair is shorted.
Small blue circles - FET transistors, one for each pair of bipolar transistors. Sometimes fail when the bipolar transistors fail. Test and replace if shorted.
Yellow circle. Picofuse. Test and replace if open.
PlainBill
Old 11-10-2010, 09:56 AM   #129
alexanna
alexanna's Avatar
City & State: st.louis mo
The2 gray capacitors in the area of PlainBills Red circles are known for poor solder joints also. If you gently wiggle them sometimes you will see the solder move.
Al.
alexanna is offline   Reply With Quote
Old 11-10-2010, 10:39 AM   #130
coolcurrent
thanks for the fast response, i'll do my homework and give feed back tomorrow.
without a sucker, which method is best for removing components with a soldering iron, i presently use brush with trimmed tips, but the brush seems to go bad quickly after few uses
Old 11-10-2010, 11:28 AM   #131
coolcurrent
PlainBill
Hello, thanks i solved the problem by just entirety de-soldering the two transformers you mentioned and re-soldering them again.
i will be watching it for a day or two
thanks
Old 11-10-2010, 12:41 PM   #132
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
thanks
Cool!!! You might also consider buying a lottery ticket. You might get lucky twice. Not only was the problem easy to fix, but nothing was damaged.
PlainBill
Old 02-10-2011, 07:14 AM   #133
josh_zedlav
Hi Folks I'm New here I need help regarding may Dell E153FB.. I've been working on my monitor for almost 3 days.. I tried all i have read from this forum like changing the 4 transistors, resoldering the transformers and other components, and changing the fuse.. It's just that it still keep on turning on and off.. Any possible solution you can give guys? thanks in advance
josh_zedlav is offline   Reply With Quote
Old 02-10-2011, 07:37 AM   #134
Welchs101
City & State: Cary, NC
Line Voltage: 120V 60Hz
Have you checked the "bulbs"?
If its turning on and then abruptly turning off then you might want to check the bulbs.
Welchs101 is offline   Reply With Quote
Old 02-10-2011, 10:59 AM   #135
retiredcaps
City & State: Canada
How long does it stay on? 2 seconds? 2 minutes? 2 hours?
--- begin sig file ---
--- end sig file ---
Old 02-10-2011, 12:36 PM   #136
EGuevarae
EGuevarae's Avatar
City & State: Chiriaco Summit, CA - near the AZ-CA Border
Caps?
  • ASUS ROG Maximus IX Code
  • Intel Core i5-7600K 3.8GHz
  • Windows 10 Pro x64
  • GeForce GT1050
EGuevarae is offline   Reply With Quote
Old 02-10-2011, 08:37 PM   #137
josh_zedlav
hi tnx for the reply.. can you tell what is the proper way of checking the bulbs? another problem i encountered is that I cannot push the button while the lcd is on this mode.. It only took seconds to turn on and off.. then long minutes on then off again
Old 02-15-2011, 07:22 AM   #138
rukirie
I just wanted to share my experience:
My father-in-law had a Dell 153FPB that 'died', i.e. had no backlight.
I saw it flash a bit when I plugged it in so I decided to google a bit to see if these things had a common point of failure (usually bad caps in my experience).
Fortunately, I read this forum and that pointed my attention to the PF751 fuse, not very obvious for an amateur like me I must confess.
I measured great resistance over the PF751 fuse, an indication of a blown fuse, so I replaced it with a 2A slowblow fuse and lo and behold!
We have a backlit image again! I hope the new fuse holds.
Thanks for the groundbreaking work,
Eric Benedikz
ps.saw this picture of the culprit:
http://s807.photobucket.com/albums/y...g=Dell+E153FPB
rukirie is offline   Reply With Quote
Old 02-15-2011, 09:01 AM   #139
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Eric Benedikz
Important!!! Resolder all inverter transformers or you will be replacing the fuse again. And some transistors.
For future reference, note the links in my signature on the proper way to attach pictures.
PlainBill
Old 02-15-2011, 10:05 AM   #140
EGuevarae
EGuevarae's Avatar
Question Re: Dell E153FPB Back Light problem
I measured great resistance over the PF751 fuse, an indication of a blown fuse, ...
