Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 07-22-2011, 07:09 PM   #1
severach
City & State: Michigan
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Single Capacitor Failure on M2N68-LA, may be a counterfeit Panasonic
I got an M2N68-LA 513426-001 in with 1 bad cap. The cap is original, not a recap. It starts but the CPU fan shuts down after a short time. No POST. Vcore has no waveform and measures 0v. Port 80 post card shows only 00. Replacing this one cap made the board work.
Normally Vcore can tolerate a cap or two loss but this one couldn't. Does anyone see the design flaw that causes this intolerance? Why did Vcore shut down?
Since it was a Panasonic that failed while the UCC KZG are still going strong I decided to photograph it next to the same series capacitor pulled from a Dell board. A Panasonic shouldn't have failed for any reason in this position. The sawtooth on the lines of the minus stripe are not photo artifacts. They are actually there. Is HP allowing suppliers to buy fakes?
GX280 Panasonic FL: Good shape, small print, smooth lines, date code 46IIUS
M2N68 Panasonic FL: Bulged top and bottom, rough lines, large print, date code 96IEA
severach is offline   Reply With Quote
Old 07-23-2011, 05:44 AM   #2
lmcancu
City & State: Montreal, Canada
Default Re: Single Capacitor Failure on M2N68-LA, may be a counterfeit Panasonic
I see the sawtooth on both caps? I had a bad power supply explode and take out a single cap on the MB which caused the MB to stop working. Replacing the cap fixed the board.
lmcancu is offline   Reply With Quote
Old 07-23-2011, 06:46 AM   #3
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
I have several Dell boards with FL's here now and no sawtooth on the lines.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 07-23-2011, 06:51 AM   #4
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
That is definitely a shoddy print job there... but if fakes have gotten this good, then we should be worried.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 07-23-2011, 07:33 PM   #5
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
Fakes...
I've replaced "Panasonic FLs" where the bung had the 'circle' pattern that Evercons, GSCs, Fuhkyoos all have/had. Not the 'base' that a real one has.
Those are so good, they're bad. I've got a whole bunch of various FCs and FMs, none have that 'aliased' printing. What the hell did they do? Take pix of real caps and manipulate them when printing the fakes' sleeves?
The bungs are different in each fake, so it's not like there's any consistency- either outside or inside.
One is too wide and not high enough, the other is a bit too small. "Hard shiny bumps" instead of a uniform smooth rubber appearance. Sleeves of differing 'shrink,' etc. Sacons and Asiacons pretending to be Panasonics- real cute.
-Paul
"pokemon go... to hell!"
EOL it...
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is offline   Reply With Quote
Old 07-24-2011, 12:11 AM   #6
severach
Both fakes or just the HP? I ask because Panasonic failures are very rare on Dell so are likely to be The Real Thing (tm).
Old 07-24-2011, 12:27 AM   #7
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Unless previously recapped by someone that gets caps from ebay.
Old 07-24-2011, 02:03 PM   #8
Derek23
Seems fake: wrong font, I think that Panasonic doesn't use Arial in its printing.
Derek23 is offline   Reply With Quote
Old 07-25-2011, 02:03 AM   #9
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
looks like its on vcore.likely shorted.would explain why one cap took it out of service.and i have several unused fj and fl fakes i got in a big lot of surplus.
kc8adu is offline   Reply With Quote
Old 07-25-2011, 05:26 AM   #10
c_hegge
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
They look genuine to me. As a general rule, if it came from a motherboard it's real. I'd say it was either overheated, killed by a bad PSU or was just a dud.
c_hegge is offline   Reply With Quote
Old 09-01-2011, 05:33 PM   #11
craig1427
I am currently having the same symptoms. With no visible bad capacitor. Coul you please tell me exactly which one it was that you replaced?
Thanks in advance
craig1427 is offline   Reply With Quote
Old 09-01-2011, 06:21 PM   #12
c_hegge
c_hegge's Avatar
when you have bad caps, replace ALL of them, bad or not. Knowing ASUS, you probably have KZG caps, which often fail without bloating.
Old 09-01-2011, 06:43 PM   #13
craig1427
Good idea and thanks
Old 09-01-2011, 07:08 PM   #14
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Or OST, which do the same.
