Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 01-13-2006, 02:06 PM   #1
solderman
solderman's Avatar
Default KY or LXY of United Chemi-Con
I have to replace some caps on my motherboard.
They are 1500uf 10v 10Wide x 20Long 105degrees C made by Sam Young.
I have my choice to replace them with United Chemi-Con KY series 1500uf 10v 10Wide x 25 Long 105 degrees C
Or
United Chemi-Con LXY series 1500uf 10v 10Wide x 30Long 105degrees C.
The KY series are rated Endurance with ripple current: 4000 to 10,000 hours at 105degrees C. The LXY series are rated Endurance with ripple current: 2000 to 8000 hours at 105degrees C.
What would be the best, last the longest?
I have heard that the ones with the longer cases last longer, but the shorter KY series are rated better than the longer LXY series. The KY series were cheaper than the LXY series at DigiKey. If they are better, why would they be cheaper?
BTW, I have no restrictions on the length, either size will fit.
solderman is offline   Reply With Quote
Old 01-13-2006, 02:20 PM   #2
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default Re: KY or LXY of United Chemi-Con
same with panasonic at digikey. FM better than FC and cheaper.
willawake is offline   Reply With Quote
Old 01-13-2006, 02:30 PM   #3
solderman
solderman's Avatar
Do you think I would better better off to use the KY series?
Old 01-13-2006, 03:11 PM   #4
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
hmmm what you think guys?
http://www.chemi-con.co.jp/cgi-bin/C...cgi?pdfname=ky
http://www.chemi-con.co.jp/cgi-bin/C...gi?pdfname=lxy
Old 01-13-2006, 04:22 PM   #5
Chris1992
City & State: Michigan, USA
Go for the KY if they are cheaper than LXZ, like willawake said the Panasonic FM are both cheaper and better than FC, it's the same with KY vs LXY.
The great capacitor showdown!
Chris1992 is offline   Reply With Quote
Old 01-13-2006, 04:28 PM   #6
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
The two series use somewhat different electrolyte technology. KY is lower Z, rated for higher ripple current, and longer life. I'd go with the KY and suggest smiling as you write the check.
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 01-13-2006, 04:50 PM   #7
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
hahaha i like it how you both arrived at the same answer via assumption/science respectively
it is curious that LXY is available in minimum 10v whilst KY gives the usual mobo required 6.3v. it is like they werent designing for that.
Old 01-13-2006, 05:23 PM   #8
MD Willington
MD Willington's Avatar
City & State: WA, USA.
KY, they must slip in the holes a little easier...
OOPs, I thought it was open mic night..
lol
MD
Ya'll think us folk from the country's real funny-like, dontcha?
The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
MD Willington is offline   Reply With Quote
Old 01-14-2006, 01:09 AM   #9
linuxguru
The KY has lower ESR and higher ripple current, but the endurance is comparable (6000 hours vs. 5000 for the LXY) for the 10 mm diameter. I'd agree that the KY is better for motherboard use.
linuxguru is offline   Reply With Quote
Old 01-14-2006, 05:00 PM   #10
PeteS in CA
I was commenting to a co-worker yesterday about the cultural thingy wrt the KY series name. I think the LXV and LXZ series cover a wider range than the LXY.
Old 01-18-2006, 05:19 AM   #11
solderman
solderman's Avatar
Thanks for all your advice.
I done my first recap job and installed 11 1500uf 10v 10mm x 25mm KY series of United Chemi-con caps on a dead motherboard, and have brought it back to life. So far so good everything is running great.
I do however think I may need to replace a power mosfet that I know got hot by the looks of the board. But I have posted that at http://www.badcaps.net/forum/forumdisplay.php?f=8
Old 01-18-2006, 05:23 AM   #12
solderman
solderman's Avatar
Sorry here is a better url
http://www.badcaps.net/forum/showthread.php?t=1304
