Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 12-19-2008, 08:37 PM   #41
leekh
Default Re: TAICON Capacitors?
oic. but somehow i am still a little worried about my current biostar socket 478 board. it is armed with HMs and KZGs on the VRMs. the rest of the board is armed with OST RLPs and the super-small RLGs without vents. 2 chemicon polymers are located near the AGP slot though.
currently using at silverstone ST400 psu, with 2x 12cm fans, 1 intake and 1 exhaust. the psu fan (also 12cm) also act as exhaust fan. cpu is a pentium 4 2.8GHz northwood.
not sure how long this system can last. but so far still so good.
leekh is offline   Reply With Quote
Old 05-17-2009, 04:55 AM   #42
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Armed is a good word for a ticking bomb.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 02-04-2011, 12:39 PM   #43
abuthemagician
Not to dredge up an old thread (mods you can kill my comment if you like) but I have 5 or 6 Netgear FSM7326P POE network switches with the 12mm x 8mm 6.3v 1000uf taicon caps that are green in color and every one is bulging.
abuthemagician is offline   Reply With Quote
Old 02-04-2011, 02:13 PM   #44
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Had a bunch of ASRock K7VT4A+ Socket A boards (Via KT400 chipset).
all the 6.3V 1000F caps were those ugly green Taicon HD's..
one of those boards was my own one from around 2004 or 2005.. got replaced by a P4 2.6GHz box because it became kinda unstable. i put it back in the box and forgot about it.
got a couple of those in for recapping and remembered that i had that very same board and went searching for it.
found it buried in the basement, opened the box and found every single one of those Taicons had popped..
i know that none of them was visibly bad back then (otherwise i would have had a clue why it was becoming unstable), so in conclusion, they must have all popped just from sitting around unused for years..
Scenic is offline   Reply With Quote
