Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 06-17-2006, 11:09 PM   #21
davmax
davmax's Avatar
City & State: Perth Western Australia
Default Re: Unknown Capacitor Brands
Hitano caps do not have the same ultra low ESR that the latest caps do. I have however seen no complaints about them.
A number of us outside the US are trying Samxon caps with very good performance. No problem has yet been witnessed with this range however the Badcaps site does not yet support their use in that there has been insufficient testing.
I am in Perth and have suffered the same difficulty in getting the right caps, so have turned to Samxon. If you are interested you can email me and I can help you meet your need. Being an OFF forum communication this will then not implicate the Badcaps integrity or status.
Gigabyte EP45-DS3L Ultra Reliable (Power saver)
Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
160Gb WD eSATAII Server grade for backup.
Samsung 18x DVD writer
Pioneer 16x DVD writer + 6x Dual layer
33 way card reader
Windows XP Pro SP3
Thermaltake Matrix case with 430W Silent Power
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanks
davmax is offline   Reply With Quote
Old 06-18-2006, 12:17 AM   #22
tazwegion
tazwegion's Avatar
City & State: Victoria
My Country: Australia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Thanks davmax, I appreciate that... lately I've even sourced ex-Australian Army surplus capacitors 1000uF 10v, you get those Samxon's from Jaycar's (and their dealers/agents) right?
tazwegion is offline   Reply With Quote
Old 07-14-2006, 10:43 PM   #23
lucius_mckaine
im currently using caps named "G-LUXON" they work fine what company made this caps is it similar to rubicon or chemi-con?
lucius_mckaine is offline   Reply With Quote
Old 07-14-2006, 11:05 PM   #24
Shroomie
City & State: New Hampshire, USA
G-Luxons are known bad caps. Not the worst of the worst, but keep an eye on them.
I've seen Hitanos as secondary caps on some mediocre AT PSUs. They all looked fine though.
You know there's something wrong when you open up a PSU and are glad to find Teapos.
Why I don't buy cheap cases!
Shroomie is offline   Reply With Quote
Old 07-14-2006, 11:07 PM   #25
linuxguru
G-Luxons are on the bad cap list - they're nowhere near as durable as Rubycon, Nichicon, Chemi-con, Panasonic or Sanyo low-ESR series. However, they're not the worst caps out there, and in a pinch they can be used for non-critical bypass applications on a motherboard - where high ripple currents are not likely to be seen, like near the Southbridge or audio sections.
They're definitely *not* recommended for use in the VRM, DIMM or Northbridge sections.
linuxguru is offline   Reply With Quote
Old 07-15-2006, 04:09 AM   #26
Rainbow
City & State: Slovakia
I've recapped Abit BX133-RAID board for a fried maybe 2 or 3 years ago. I didn't have any caps so he bought some - G-Luxons, probably not low ESR and 85 degC. The board still works - so I think that maybe only some series go bad (low ESR ones?)
edit: found two of the caps - it's G-Luxon GR
Rainbow is offline   Reply With Quote
Old 01-31-2007, 05:23 PM   #27
Stagea
Stagea's Avatar
I bought some Samhwa 450V 47uF caps in 2000 for the HT supply on a valve amplifier I made. I had no idea about good caps/bad caps then. I was thinking they were probably alright, as they'd done 6-7 years without problem, but I just checked them now, and hello, a couple of them are bulging, so they'll all need replacing.
Interesting site. Seems like everything I open is full of bad caps! My router is Teapo, and it's been playing silly buggers, so I'll do those. My too-expensive short wave radio has also started playing up, and it's full of Su'scon and YEC caps, so I might see if replacing those helps, but otherwise I'm blindly stumbling there.
Stagea is offline   Reply With Quote
Old 02-01-2007, 07:06 AM   #28
gonzo0815
City & State: Germany
Samhwa is not absolut crap, but shure this are not long endurance caps. But theyr cheap ;-)
I mean 5 to 6 years is something, most conventional vendors are considering a too long lifespann. Two or three years ar in most cases all they want, as at this time warranty periods are in most cases in that region.
gonzo0815 is offline   Reply With Quote
Old 02-01-2007, 08:47 AM   #29
linuxguru
Samwha used to be crap, but after they purchased the electrolytic capacitor division of Samsung in 2001, they're slightly better. However, they don't make low-ESR and ultra-low ESRcaps for motherboard/VRM use. They're OK for general purpose, 85c, standard capacitors in low-current applications like audio, general bypass, low-power sections of TVs/monitors, etc.
If you see them in a PSU/high-current application, it's best to recap them preemptively.
Old 02-01-2007, 10:48 AM   #30
Phenos
Phenos's Avatar
City & State: The netherlands
I had some Yageo capacitors here, About a year ago these were the only low impedance capacitors i could find.
They look exactly the same as Teapo capacitors.
Phenos is offline   Reply With Quote
Old 02-01-2007, 11:28 AM   #31
Rainbow
I have a bag of new Yageos - some of them have Teapo-like vent, some standard cross vent.
Old 02-02-2007, 09:13 PM   #32
Howie
How about Elite brand? Just cleaned out dust bunnies from a very nasty PSU which is at least 2-3 years old and they all looked fine.
Howie is offline   Reply With Quote
Old 02-02-2007, 09:42 PM   #33
linuxguru
I've seen lots of failed Elites, usually on falsely-rated '300W' PSUs used on P4 systems. Usually the ones on +12V go first, followed by +5V, +5Vsb and +3.3V.
Old 02-03-2007, 07:30 AM   #34
gonzo0815
I would consider Elite as crap, but it seems that they be the standard in todays crt Monitors and many other SOHO appliances.
Old 02-12-2007, 11:33 AM   #35
splaz
City & State: Perth, Western Australia
Never mind, taking it accross to PM as I just checked the date.
splaz is offline   Reply With Quote
Old 02-12-2007, 07:47 PM   #36
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
i just pulled a bunch of elite from an asus p4c800 board.
they were not bulging but sizzled and stunk as i desoldered them.
several measured .5 ohm esr.
which is terrible for this type of cap.
kc8adu is offline   Reply With Quote
Old 02-14-2007, 04:49 AM   #37
splaz
Well this isn't in anything quite as high stress as in a motherboard or PSU but a linear power supply I have to build in kit form for a course has "Sun" axial filter caps.
Anyone heard of them ?
Thinking of replacing them with BC ones.
Old 02-14-2007, 06:35 AM   #38
davmax
davmax's Avatar
You are right the stress in a linear PS input filter is not as critical. Do you really need to replace those Sun caps? If it works fine let it be.
Old 02-14-2007, 06:55 AM   #39
splaz
Well they work fine as far as I know. Just was considering it might just be better in the long run to use something a bit more reliable and better quality, as I can't even find anything at all on that brand.
Old 02-19-2007, 01:28 AM   #40
akuhon
Hai all,
I'm a newbie in this community.
I'd like to know if you've ever heard about caps brand "GERLIN" .....
It was taken from a redundant powersupply BPS-270RDX, here
Is this good or bad ..... I can't find any info on the i-net and so in this forum....
Hope someone inform me about this capacitor (info / datasheet, etc)
I will take the pics later ....
TIA
akuhon is offline   Reply With Quote
