Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 12-06-2017, 08:23 PM   #1
steves7839
City & State: Atlanta Area, GA
My Country: USA
Line Voltage: 120VAC 60HZ
I'm a: Knowledge Seeker
Default HP22 2sec to black CCFL to LED conversion
I installed two LED strips with the included driver into this 22" monitor. The screen is nice and bright now. But no menu or sound.
Before surgery the monitor showed a welcome "no source connected" screen for about two seconds. Most of the display around the welcome screen was dark. It then powered off the backlight.
If the display is now all white, does that mean no video signal is getting to the LCD panel? Or maybe I just put the polarizer, glass plate and LCD panel back together in the wrong order.
Suggestions?
The model number is W22; the panel is Chi Mei M220Z1-L01
steves7839 is offline   Reply With Quote
Old 12-07-2017, 09:38 AM   #2
boyebaran
City & State: tehran
My Country: iran
Line Voltage: 220VAC 50Hz
Default Re: HP22 2sec to black CCFL to LED conversion
hi
you must disable protecting by controler ic .
please upload clear picture from ic or send part number.
protect means when one of component have problem(ccfl-high voltage and.....)ccfl controller ic shutdown power supply for avoid further damage.
you disconnected ccfl from board and ic not sense ccfl and gone to protect
boyebaran is offline   Reply With Quote
Old 12-08-2017, 07:36 PM   #3
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Did you verify that LVDS cable at the LCD PANEL is secure back in properly when you put the unit back together? You may also have to verify that you do have either 5V or 12V at the smd fuse on the T-CON on the LCD panel assembly or not.
__________________
budm is offline   Reply With Quote
Old 12-08-2017, 08:09 PM   #4
steves7839
My Country: USA
Thanks for the replies, guys!
Here's a picture of the main board; is this the controller IC you mentioned? Or is it on the power supply near the inverter section?
BudM, the T-Con appears to be incorporated in the circuit board attached to the LCD panel. There's no twisted-pair LVDS cable, just a flat cable to that board from the main board.
Also, I forced the backlight on using a 3.2V from the main board, but have not connected the dimmer line to the new LED driver board. I guess that means no brightness control.
Old 12-08-2017, 08:41 PM   #5
budm
budm's Avatar
My Country: USA
I know that the T-CON is integrated to the LCD panel assembly, that flat ribbon cable is the LVDS cable which also provide either 5V or 12V to run the T-CON board and there is connector on that integrated T-CON board. BTW: LVDS cable does not have to be twisted pair, just about all monitor and TV use flat cable these days.
There is no error feedback signal used in this monitor to tell the logic board to go into shutdown if the backlight circuit detects the error, so it at this point the inverter circuit does not matter any more and the power going to the inverter section should be disconnected.
So do you have 5V or 12V at the T-CON or not?
Old 12-08-2017, 09:07 PM   #6
boyebaran
My Country: iran
Quote:
Originally Posted by boyebaran View Post
hi
ic placed under inverter board.
Old 12-09-2017, 03:48 AM   #7
Dumah Brazorf
City & State: Brescia
My Country: Italy
Line Voltage: 230VAC 50Hz
Isn't backlight circuit independent from the image circuit?
I mean, usually if backlight shuts off you can see the image on the screen anyway using a flash light.
So probably the lcd is dead.
Where did you hook the power for leds?
Dumah Brazorf is offline   Reply With Quote
Old 12-09-2017, 04:40 PM   #8
budm
budm's Avatar
My Country: USA
That is correct! That is what I am trying to get through, there is no feedback from the backlights circuit to tell the main board to go into shutdown, that is why you can still see image on the screen using other light source when the backlights are not working.
Old 12-11-2017, 07:58 PM   #9
steves7839
My Country: USA
In the photo of the LVDS connector, the pin closest to U202 has 5.1V for the first minute or so. It then goes to 0 as the monitor's power LED goes from green to amber. There is no picture, even by flashlight.
In the other photo there is a solder blob next to C211. I don't remember seeing it there at first inspection. I soldered the wire for the LED backlight power to the open pad for U202 and jumpered from CN201-12 for the BL enable wire.
I will have to disassemble to check the voltage at the other end of the ribbon cable, so will do that tomorrow.
Old 12-13-2017, 03:54 PM   #10
Dumah Brazorf
My Country: Italy
So are you powering that leds @5V? Aren't these kits work with 10V to 30V?
I don't think 5V line is beefy enough to power everything. You should power leds from the same line that serves the ccfl inverters.
Old 12-14-2017, 08:27 AM   #11
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Most likely it would be 12V used to supply the CCFL circuit. That 12V MUST be disconnected from the CCFL circuit. That is the supply that should be used to power the LED Driver Bd. Also, the BL ON/OFF and DIM control MUST be connected to the LED Driver Bd. and taken from the Main Bd. or where the CCFL circuitry was getting those signals. Short cuts don't work in these cases.
Andrew F. Ali is offline   Reply With Quote
Old 12-14-2017, 04:50 PM   #12
steves7839
My Country: USA
The LED power board in the kit accepts 10-30VDC. I am powering it with 12V from the main board and using 3.4V for enable. I don’t yet know where to connect the “dim” input on the LED power board.
Old 12-15-2017, 06:02 PM   #13
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Quote:
That appears normal. The power going to the T-con board should be OFF when the monitor's LED turns amber. But, if you still see a white image with the monitor's LED being green, then that means either the T-con is not getting proper signals from the logic board (due to dirty and/or misaligned LVDS cable) or due to bad inverter supplie(s) on the T-con board (though, I am not sure how you changing the CCFLs for LEDs would damage the T-con board's power supplies, so try re-seating the LVDS cable a few times and make sure its contacts are clean).
Old 12-17-2017, 07:35 AM   #14
Dumah Brazorf
My Country: Italy
Check the 12V when on.
Disconnect temporarily the new backlight and check with a flashlight if there is image.
Old 01-03-2018, 05:41 PM   #15
steves7839
My Country: USA
It's fixed. Once I reopened the panel I found the LVDS ribbon cable loose. I also connected BL Enable to the inverter enable signal.
Since I had no input connected, the display went dark and the unit's power LED went amber after a minute, normal behavior.
Thanks for the suggestions!
Old 01-06-2018, 10:36 AM   #16
momaka
momaka's Avatar
My Country: U.S.A.
Good to hear you got it working!
Old 01-09-2018, 10:15 PM   #17
budm
budm's Avatar
My Country: USA
Glad to hear, as suggested in post #3 for what to check.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
